Old 09-29-2008   #1
CarPsyco84
CarPsyco84's Avatar
motor loads when clutch pedal pressed
This is something new, that I haven't seen before... The engine becomes loaded, like you just turned on 8 head lamps, when you press the clutch pedal down... Doesn't do it when the engines cold, but the warmer the engine is, the worse it gets... I had to raise the idle or it would die when you press the clutch pedal down... I'm thinking/hopeing throw out bering, and not some motor issue, makes no audible noises either... I'm baffled
-When in doubt, Moar RPM.
Old 09-29-2008   #2
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Re: motor loads when clutch pedal pressed
Does it try and creep foreward if it's in gear, clutch in, and no brake?
Old 09-29-2008   #3
Crankwalk
Old 09-29-2008   #4
I think Shane's right. Have someone push on the clutch pedal while you look down the timing belt side at the harmonic balancer. You'll be able to see the pulley move in and out.
Old 09-29-2008   #5
Yea thats usually a crankwalk symptom
Old 09-30-2008   #6
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
but he has a 6 bolt???
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 09-30-2008   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
It can still happen.
Old 09-30-2008   #8
311evo
311evo's Avatar
Crankwalk
oh noes. GL on finding the problem.
not to be another bearer of bad news, but my eclipse was doing that before it took a walk.
Old 09-30-2008   #9
CarPsyco84
CarPsyco84's Avatar
thats what I was afraid of... but my crank should be fine, its just the thrust bering that must be worn out then. unlike the 2g's that have bad cranks
Old 09-30-2008   #10
CarPsyco84
CarPsyco84's Avatar
yep.... its walking... dunno what the end play limit is, I'm guessing a good .020" or more when you press the clutch...
Old 09-30-2008   #11
I have seen 6-bolts with destroyed cranks and blocks from crankwalk.
Old 09-30-2008   #12
seen that also it happed to one of craigs blocks and cranks,because crank shaft supply was to polish the crank and they cut it and did not tell us. the crank destroyed the block and oil pump in a month. they ended up buying a new mistu block and crank for us for there fuck up
Old 10-04-2008   #13
CarPsyco84
CarPsyco84's Avatar
well 6 bolt motor guys should take note... you are not immune to crank walk. I didn't bother to measure the walk in this but its at least .020"
ID:	7801   Click image for larger version
Old 10-04-2008   #14
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
walkathon for breast cancer
Old 10-04-2008   #15
dsm9sec
Drives: ... More than you can afford, pal
If you build it right there's very little chance.
dsm9sec is offline   Reply With Quote
