Old 08-18-2008   #1
Engine Clanking -WTF!!!
Well my car is screwed for awhile now I'm thinking. Here's a quick run-down of what just happened about 20 minutes ago.
** Just got my new TB installed the other day. I started up the car and got the TPS dialed in. Let the car warm up and set the Idle Screw so the car was idling nicely at about 1k. Everything sounded great, and I noticed the car was low on gas. Decided to make the 1 mile round trip to the gas station to fill it up. Got to the gas station, car seemed to be running just fine. Never even got it past 55mph, just a nice leasurly drive.
Filled it up, decided to get a car wash on it since it had lots of water spots and left over pink powder residue. Drove into the car wash, shut the car off. Car wash was done, turned the car on and drove through the dryer. About that time I realised my Tach wasn't working. Once I got back on central, it started bouncing around like maybe there was a loose connection or something. Figured maybe the water from the car wash was messing with the tach signal. I turned on DSMLink, and it was logging RPM's correctly, so I continued on since home is 2 stop lights away.
I'm still driving it normally, no hard accelleration at all. All of a sudden when I'm maybe 200 yards from the 2nd stop light, CLANK CLANK CLANK ***SH!T BOUNCING AROUND IN THE MOTOR *** CLANK CLANK.
Noticed a very very small amount of smoke coming from the rear of the car. Coasted it into the parking lot. First thing I do is pop the hood and look for something obvious. Nothing obvious. I look under the car for any fluids pouring out. Nothing. I crank the motor real quick and it sounds like the compression isn't so hot anymore.
I will be waiting a minute for the sun to go down and traffic to lighten up, and tow it home (only 30 seconds away).
I have no idea as of right now, wtf happened. Car seemed to be running fine. It was idling beautifully, running just fine. Then all of a sudden at maybe 4k RPM, 1/4 throttle, CLANK!
I'm so pissed right now, especially with the DYno Day on Saturday.
Anyone have any ideas or pointers? Is it a coincidince that this happened 1 minute after the RPM gauge stopped working?
Soon as I get it home, first things I'll be doing is removing the valve cover, spark plugs, timing belt cover, and draining the oil which I'm pretty sure will be completely full of metal shavings.
Old 08-18-2008   #2
Re: Engine Clanking -WTF!!!
That really sucks Brandon
Old 08-18-2008   #3
polishmafia
Smells like cat poop
polishmafia's Avatar
Damn
I wish I could help figure out what it could be. If you need a helping hand tearing into it, call me.
Old 08-18-2008   #4
johnson
johnson's Avatar
Drives: 90mitsu
check plugs?
maybe you will have your answer!
lets hope you didnt break a valve(s)!
Old 08-18-2008   #5
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
That's bad news!! I'm sorry man..
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-18-2008   #6
Opened up the valve cover, noticed this...
Then found this...
Pulled out the plugs. That broken rocker was from Cylinder 1. But when I removed the Cyl 1 plug, the gap seemed a little off, but I think I got it better now after getting some advice from Tom (Tpunx).
I compared all 4, they all look good right? Anyone have any advice?
I think my engine took a big
Old 08-18-2008   #7
Ouch! That sucks man.
Old 08-18-2008   #8
On a positive note, I drained all the oil. The oil has, well, 1 mile on it, and it appears to be pretty clean.
I'll slowly be getting the head off the car to see how it looks inside and see how bad the cylinder walls look. I'm going to go ahead and assume the head is shot. Any body have a single roller rocker they'd be willing to part with?
Old 08-18-2008   #9
Will you be listing it for sale in the classifieds?
Old 08-18-2008   #10
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
I got a whole bag of em. and a lifter, and valve spring. I also have a head if you need it. Just let me know.
Old 08-18-2008   #11
johnson
johnson's Avatar
Drives: 90mitsu
as i figured man! lets just hope it was the rocker that was makin the clank! and not the valves! mine was worse! i still have that spark plug somewhere! but that sucks man! i also broke 3 valves off into pistons and scarred the walls bad!
Old 08-18-2008   #12
Yeah, but the rest of that spark plug has to be in there somewhere. Tomorrow after work it looks like I'll be ripping the head off.
Old 08-18-2008   #13
Yes, along with those 4 slightly used spark plugs. Deal of the century!
I've been trying to figure out what the Tach runs off, because I find it odd that this happened right after the tach starting going bazerk. Does it run off the CAS? I just checked, and it seems to be plugged in nice and tight. I wonder if the CAS is on it's way out?
Old 08-18-2008   #14
johnson
johnson's Avatar
Drives: 90mitsu
yeah it melted/warped the shit out of my head too! mine happened right after a rebuild, my lil bro took it for the first test drive and came back without the car! dsmers worst nightmare! haha....
Old 08-18-2008   #15
See if you can check the height of the top of the piston in cylinder 1 in relation to cylinder 4 with both at TDC. Stick two equal length pencils or somethign in there and measure the tops. Unless there something in there like a broken valve stem, there's not much that could do that to your spark plug. Hopefully it's nothing. I might be able to drop by later tomorrow night if you need an extra set of eyes.
Old 08-18-2008   #16
That spark plug was very hard to remove. I'm pretty sure even if the rest of the head is somehow magically fine, I'll still have to put a helicoil or do something with that spark plug hole. The heads coming off.
If you want to stop by though, please do so. Maybe I'll have the head off by the time you're here, and you can give me some pointers on how the rest of everything looks (cylinder walls, piston tops, etc.)
Old 08-18-2008   #17
Wow, that really sucks Brandon!
Old 08-18-2008   #18
shitty. I have a few rockers and a compleat head sitting here
Old 08-18-2008   #19
holy shit. I just dont understand how that happened to the plug?
Old 08-18-2008   #20
jhaan_dude
jhaan_dude's Avatar
Drives: a car
wow, i would check for the rest of the parts of the needle bearing.....
