Old 07-11-2008   #1
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
FS: Brand new 91-94 FWD tranny
Brand new 91-94 FWD Turbo transmission out of the crate from Mitsubishi ($2200 ). Not sure what the exact year is but I believe it may be a 94 tranny. It has been sitting in my garage tucked away. I had plans to use it but going a different route. Comes with brand new: Slave cylinder, Clutch fork, Motor mount, and TOB. Has never been mounted or used.
Asking $1800 + shipping o.b.o.!
Will have pictures up asap.
Old 07-13-2008   #2
desolate
91 TSi AWD
desolate's Avatar
Re: FS: Brand new 91-94 FWD tranny
Here are the pictures:
Old 07-13-2008   #3
desolate
91 TSi AWD
desolate's Avatar
Forgot to mention VIN #s are:
F5M332SP7S
JL2083
Old 07-13-2008   #4
DontStopMe
DontStopMe's Avatar
Bejeweled Champion!
Drives: Camaro
F5M332SP7S
JL2083
Thats not the VIN. But the VIN should tell you the year. 10th digit.
http://www.wi-dsm.com/forum/showthre...=1630#post1630
more info above.
www.boostedfilms.com
-Paul
2003 IS 300
1979 Chevy Camaro
1993 AWD DSM
DontStopMe is offline   Reply With Quote
Old 07-13-2008   #5
desolate
91 TSi AWD
desolate's Avatar
Without spacing the entire vin apart it reads: F5M332SP7SJL2083. However that indicates that it's a 95 transmission? There are two other numbers in different locations
This one is around the bar code: BJL2083-SPZS
and another KM210
Old 07-13-2008   #6
brando
Drives: gutlass
areful they are slightly different in a few aspects
Old 07-13-2008   #7
desolate
91 TSi AWD
desolate's Avatar
As far as bolting up goes a 91-94 transmission will fit no problems. The shifter cables and shifters are the same. Internally there are some differences. The later years came with I believe double syncro in some gears primarily 2nd gear. They are internally stronger than the 90s. There are some more internal differences also.
Old 07-13-2008   #8
desolate
91 TSi AWD
desolate's Avatar
Reading the 1000 questions asked:
Note that 2G transmissions are interchangeable with 1G transmissions of the same model number, but 2G transmissions have different internals and are generally considered to operate much better. Usually only minor modifications are required to fit a 2G transmission to a 1G engine.
I'm thinking mitsu used a 95 core and internals but intended it to go into a 91-94.
Does anyone know how to completely decode the transmission vin?
Old 08-18-2008   #9
blageo23
AWD4G64
blageo23's Avatar
Actually, you can put a 2g tranny in a 1g but you cannot put a 1g tranny in a 2g.
1998 Spyder AWD
567hp
490tq
Old 07-14-2008   #10
DontStopMe
DontStopMe's Avatar
Bejeweled Champion!
Drives: Camaro
as I stated earlier, you are not looking at the VIN #.
Here is a picture of where the VIN is located.
And just incase you still want to know how to decode an entire VIN#...
http://www.vfaq.com/mods/VINs.html
PS, if its a 93-94, It will have larger diameter CV-shaft inputs than the 90-92.
-Paul
2003 IS 300
1979 Chevy Camaro
1993 AWD DSM
Old 07-14-2008   #11
desolate
91 TSi AWD
desolate's Avatar
Ok found out this transmission does not have a vin engraved on it.
Old 07-14-2008   #12
DontStopMe
DontStopMe's Avatar
Bejeweled Champion!
Drives: Camaro
Thats where the VIN should be. Might have something to do with your trans being brand new, I dunno. Eitherway, F5M33 means FWD turbo.. thats all I ever got out of the top #'s.
http://members.shaw.ca/costall/1000Q...m#transmission
-Paul
2003 IS 300
1979 Chevy Camaro
1993 AWD DSM
Old 07-14-2008   #13
desolate
91 TSi AWD
desolate's Avatar
Need to move this $1500 o.b.o!
Old 07-14-2008   #14
desolate
91 TSi AWD
desolate's Avatar
After checking a buddy's transmission for a vin, his transmission has one and the new one doesn't.
Old 07-16-2008   #15
desolate
91 TSi AWD
desolate's Avatar
Two more pictures!
Old 07-17-2008   #16
desolate
91 TSi AWD
desolate's Avatar
Slashing the price! My loss your gain. This is such a deal, priced to sell! Brand New! Come take this away! $1200!
Old 07-19-2008   #17
desolate
91 TSi AWD
desolate's Avatar
bump!
Old 07-21-2008   #18
desolate
91 TSi AWD
desolate's Avatar
After triple checking the shift lever lengths, it is a 90 Transmission. Because of that I will provide free shipping.
Old 08-01-2008   #19
desolate
91 TSi AWD
desolate's Avatar
$1000 or
$1100 shipped.
Old 08-18-2008   #20
desolate
91 TSi AWD
desolate's Avatar
$900
