Go Back   MitsuStyle > Hosted Support Forums > DB Performance
Old 03-16-2009   #1
GSXMatt
You can't buy my Evo.
GSXMatt's Avatar
Drives: 03Evo,11Altima
92/E85 tune...
I'm looking to run Efuel in my Evo. Its running the stock Evo 8 turbo (03). Is it possible to get the car tuned with switchable fuel maps? Or do you guys not do that? Thanks.
99 GSX- Sold
03 Evo- More than stock.
-ATC Productions-
is dead.
I hate Mitsubishi.
Old 03-16-2009   #2
Dundars
Drives: 1g DSM
Re: 92/E85 tune...
I don't see why it wouldn't be.
Edit - Shit, didn't see this was posted under the DB section, I'm sure Shane will answer this better than I would ever be able to.
Dundars is offline   Reply With Quote
Old 03-16-2009   #3
Re: 92/E85 tune...
Before going to Shane you should setup Tephra map switching on your ECU. Its very easy to do, just research it a bit on EvoM in the ECUFlash section of the board.
Old 03-16-2009   #4
GSXMatt
GSXMatt's Avatar
Re: 92/E85 tune...
Cool, I will do just that.
99 GSX- Sold
-ATC Productions-
is dead.
I hate Mitsubishi.
Old 03-17-2009   #5
Re: 92/E85 tune...
Yes, we can do it. You would need to have your alt map switch/harness installed and working.
Old 05-12-2009   #6
jrohner
jrohner's Avatar
Re: 92/E85 tune...
Once you run E85, you won't wanna ever have to run gas again. I have way more power, my car runs better and is easier to tune, cheaper to fill up, and I only get maybe around 2 MPG less mileage.
Old 05-19-2009   #7
Gravy
Who's this guy?
Re: 92/E85 tune...
Just make sure you map out all E-85 stations around anywhere you would be driving. I've thought about going back to it, but i don't know where enough stations are around town. Close to home i'm fine, to and from school is no problem, but going up north, longer road trips. As long as you can set up to run both E-58 and gas you've got the best of both worlds.
Old 05-19-2009   #8
GSXMatt
GSXMatt's Avatar
Re: 92/E85 tune...
I've decided to just run E85. I will be able to drive the car a max of one month out of the year due to being overseas, so I don't see the need.
99 GSX- Sold
-ATC Productions-
is dead.
I hate Mitsubishi.
