Old 03-16-2009   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Will my 7 bolt hold?
I have enough mods to hit 300-350awhp and I was told it will blow up... I have arp's and all that stuff to support it. What do you guys think??
I'm planning on running 20psi on a scm6152e
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 03-16-2009   #2
Dundars
Drives: 1g DSM
Re: Will my 7 bolt hold?
Yes.
Edit - What dyno do you plan on making those numbers on? Good luck hitting 350awhp on a Dyno Dynamics at that boost level on a 2.0.
Dundars is offline   Reply With Quote
Old 03-16-2009   #3
GsXtUrBo98
GsXtUrBo98's Avatar
My goal is 300 so I wont be dissapointed if I dont make 350...
I have my upgrades on here as my spring upgrades and that has all the stuff I am running on it...
98 GSX (built)
03 BBY EVO dd
Old 03-16-2009   #4
Originally Posted by Dundars View Post
Yes.
It shouldn't be that tough depending on the mods it should be damn close, especially on E-85.
E-85 setups like this are making between 450 and 500 with big enough injectors on Dyno Dynamics.
You won't blow your motor either, there's guys making more power than this on 7 bolts just fine.
Old 03-16-2009   #5
Old 03-16-2009   #6
Dundars
Drives: 1g DSM
Stock 2g rods still I'm assuming?
If yes, that and crankwalk will be your only weaknesses, but I highly doubt you will run into crankwalk or a bent rod at that power level.
Old 03-16-2009   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Its a jaster long block with 40k on it and the balance shaft eliminated... as far as I know its all stock internals because the guy before me put it in....
98 GSX (built)
03 BBY EVO dd
Old 03-16-2009   #8
It is Jasper, and no you shouldn't have any issues at that point.
Old 03-16-2009   #9
95tsi
95tsi's Avatar
Drives: a pos
I'd think you should be fine. Shane tuned my car to 358awhp on a stock bottom end with arp's and cams using a 16g.
Old 03-17-2009   #10
GsXtUrBo98
GsXtUrBo98's Avatar
sounds good
98 GSX (built)
03 BBY EVO dd
Old 03-22-2009   #11
Yeah you'll be fine! If that was your goal thought you could have gone with a smaller turbo.
Old 03-23-2009   #12
GsXtUrBo98
GsXtUrBo98's Avatar
O its not my final goal... Just for this year!
98 GSX (built)
03 BBY EVO dd
Old 04-01-2009   #13
Do it. If it ever lets go, 6-bolt time. Otherwise, rock it.
Old 04-02-2009   #14
GsXtUrBo98
GsXtUrBo98's Avatar
Well since you put it that way!!!!!
98 GSX (built)
03 BBY EVO dd
