Old 04-16-2009   #1
green hornet
t-case leak? on 2g
i just got my car on the road after my 6bolt swap, and after taking it for a drive i noticed that i hat i have a bunch of fluid on my rear mtr mt and all over my subframe, the breether is still on the t-case, enyone have an idea where the leak could be coming from, the way the fluid is all over i think its spiting out of some place. eny ideas
FASTER AND FASTER! TILL THE FEAR OF DEATH IS OVER COME BY THE THRILL OF SPEED!!!
Old 04-16-2009   #2
Re: t-case leak? on 2g
Fluids don't usually leak up, so follow the wet areas up and that should bring you to your source. If it is the T-case, then there will probably be clean areas surrounded in dirt around the seal it may be coming from.
Old 04-16-2009   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Did you get the t case fix done from the dealer?
Amsoil Dealer
Old 04-17-2009   #4
green hornet
nope the dealer wouldnt touch it, well my tranny fluid is good and the oil is good, i just filled up the t-case and drove 2 miles to my budys house and poped the filler plug off and nothing came out, im am stumped on this one.
Old 04-17-2009   #5
95talonracer
Finally Tuned...
Drives: Spyder GSX
Well I could of told you that. You have to have it installed in the car and drive it there for them to cover it. Did you ask them to check the vin number to see if there was any outstanding fixes on it that have not been fixed yet?
Amsoil Dealer
