Old 06-11-2009   #1
6pucker
89 colt turbo part out
im taking apart the car this weekend so parts and shell wont be available until then. chassis might have to be put back together by purchaser. just the front bumper though
original 89 dodge colt turbo(same as mirage)
*chassis*
white
paint is not faded but has stains
little to no rust
220xxx miles
has some suspension mods(kyb shocks and some sort of rear sway bar)
shell is pretty clean if not the cleanest in mn. asking $1000 for shell.
evo 3 16g with 2g ported exhaust manifold with less then 150 miles $300 *sold* thanks
brand new aftermarket stock location super bling'n j-pipe $20
brand new o2 housing with external dump $40
brand new southbend dxd dual friction clutch $185
brand new mitsubishi timing belt in unopened package $30
6bolt head with 3rd gen lifters + resurface $200 *sold*
1g intake manifold with qpr block off plates $15
2g intake elbow $10
barely used greddy type s bov $125 obo *sold* thanks
1g upic hardpipe $30 (i think its a dejon pipe, also barely used)
used and cut 1g pacesetter 3 in dp $15
1g refreshed 6bolt block with new bearings, oil pump, water pump, crank pulley and all new timing components $225 *sold*
91 1g eprom ecu $115
thanks for looking and my number is 651-329-8881 ask for sia
will be adding more
6pucker is offline   Reply With Quote
Old 06-11-2009   #2
CarRacer
CarRacer's Avatar
Drives: 91 Galant VR4
Re: 89 colt turbo part out
Interested in the turbo. Where is the car located? I'm assuming no shaft play with that mileage? What diameter is the j pipe?
Old 06-11-2009   #3
Willing to sell the shocks and springs. I do have a oem set could give you with some cash
Old 06-11-2009   #4
Where are you located? And does the car still have the rear calipers on there? I'm looking for the banjo conversion fitting that is on the rear calipers.
Old 06-12-2009   #5
6pucker
the car is located in the maplewood, oakdale area. the turbo has no shaft play. im not sure on the diameter of the j pipe but i do know that it is bigger then the stock pipe, i wanna say 1.5-1.75 in?
sorry guys but i dont want to split up the shell. sorry if the title is a little misleading. just parting out motor and selling shell as a whole.
Old 06-16-2009   #6
6pucker
bump for new parts and prices
Old 06-16-2009   #7
If you want to part with the suspention let me know. I have the stock suspention in mine and cash for the set up you got. I would be willing to swap them over also
Old 06-16-2009   #8
Old 06-16-2009   #9
6pucker
sorry tkr i dont want to mess with the shell at all. just wanna sell as a shell. thanks
Old 06-18-2009   #10
6pucker
bump for eprom ecu
Old 06-19-2009   #11
6pucker
bump for new rock bottom prices
Old 06-21-2009   #12
daneatsv8s
Drives: 91 Galant VR4, 97 Eclipse GSX, 91 Talon TSI
Hey, this is Dan. I texted you a few days back about the block. Can you tell me more about the block? Did it come off a running car? Were the piston rings replaced? What brand were the water pump/timing belt components? I'm very interested and could pick it up tonight or tomorrow for 200.00 cash.
Call me back or PM me back: 612 - 381- 6195
Thanks - Dan
daneatsv8s is offline   Reply With Quote
Old 06-26-2009   #13
johnson
johnson's Avatar
Drives: 90mitsu
You got an alternator? I got $20 on it!
Old 07-01-2009   #14
6pucker
sorry johnson no alternator.
Old 07-01-2009   #15
6pucker
shell is ready to go!
