Old 08-13-2009   #1
OMGkiwi
Drives: 91 TSI
Car wont start after rebuild, HELP!
the car just cranks and cranks, the timing belt is on right but it seems to spin over kind of sluggishly, did a comp test and was at about 120 across the board im assuming that will go up when the car starts up and the rings set.
I had to take a CAS off and I didnt really know if it had to be in a certain position to work properly, but when I turn it all the way towards the firewall, the car will "pop" and want to start, but only every so often. I cannot locate the crank sensor, or is that built into the coil pack setup? theres is a small round plug that is not connected, it is on the same bundle of wires that the injectors and coil plug goes, like I said its about 1 inch and round.
I guess the first question is what should I do to test if my cas is bad? also, when I turn the key to the on position the fuel pump does not prime, but after i am done cranking it primes.
HELP!
91 TSi- Hates Me
LOL You mad bro???
OMGkiwi is offline   Reply With Quote
Old 08-13-2009   #2
OMGkiwi
Drives: 91 TSI
Re: Car wont start after rebuild, HELP!
also, I checked and have spark. car is a 91 tsi
91 TSi- Hates Me
LOL You mad bro???
Old 08-13-2009   #3
Plug wires on wrong?
There is no crank sensor on a 1G.
Old 08-13-2009   #4
OMGkiwi
Drives: 91 TSI
plug wires are on right, I double checked. then I literally took them off and put them on again using the manual.
91 TSi- Hates Me
LOL You mad bro???
Old 08-13-2009   #5
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
When you take the CAS off there is a piece that has 2 ends on it. That part slides into the cam. Turn that 180* and try to start again.
Amsoil Dealer
Old 08-13-2009   #6
OMGkiwi
Drives: 91 TSI
tried spinning it 180 with no success.
I am wondering if I am not getting fuel? when I cycle the key the fuel pump does not turn on, during cranking it does not turn on, but after cranking, the pump will cycle for approx 1 second.
any advice? thanks guys
91 TSi- Hates Me
LOL You mad bro???
Old 08-13-2009   #7
You could make sure it is getting fuel by taking off the return line, putting a new return line over the regulator and to a 5 gallon fuel jug and seeing if any fuel comes out.
Old 08-13-2009   #8
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I dont know I would have someone check the plug wires for you. Not saying your doing it wrong its just good to have a second opinion.. I ran into this with my car and it was just the wires that were wrong...
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-13-2009   #9
OMGkiwi
Drives: 91 TSI
I followed the diagram in the manual.
91 TSi- Hates Me
LOL You mad bro???
Old 08-13-2009   #10
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Motor to body ground okay?? Just take a ground & hook it from block to ground.or neg bat. terminal. Had a friends car not start because of a broken ground
Old 08-13-2009   #11
OMGkiwi
Drives: 91 TSI
I also replaced the ground wire, it was all melted?
91 TSi- Hates Me
LOL You mad bro???
Old 08-14-2009   #12
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
hmmm melted.. check for short?? or test the ground like this... http://www.ehow.com/video_2327356_us...light-car.html
you can use a test light to check for a short or draw on the battery by removing the negative cable and hooking the test light between the negative battery cable and the negative post... should not light up or only for a second but dim to almost being out immediately. If it lights up, then you know you have a short or draw somewhere.
Old 08-14-2009   #13
OMGkiwi
Drives: 91 TSI
I will do that, I am also wondering if I should pick up a new CAS.. how much is one new?
91 TSi- Hates Me
LOL You mad bro???
Old 08-14-2009   #14
john
Business as usual
john's Avatar
I wouldn't buy new... I will try and check tonight, I probably have one at the house in hopkins you can have. Where in Minnetonka are you?
97 Viper GTS
Old 08-14-2009   #15
john
Business as usual
john's Avatar
Can you take a pic of the unplugged connector? Was the car running before the motor came out?
Bad ecu???
97 Viper GTS
Old 08-14-2009   #16
OMGkiwi
Drives: 91 TSI
heres a pic of the plug.
91 TSi- Hates Me
LOL You mad bro???
Old 08-14-2009   #17
OMGkiwi
Drives: 91 TSI
Bad ecu???
a little update on the CAS. when I have the ignition turned on and spin the crank dampener to TDC on cyl 1 I can hear the fuel pump cycle for 1 second, so im assuming the cas is ok. I also added another ground from the engine to chassis, the car sounds like it wants to start but I cant get any repeatable near starts. so like the car will spin over and crank crank crank, pop, crank crank crank pop like its all loaded up. I tried un plugging the injectors and cranking it to clear it out if it was flooded, it popped a few times and then stopped, after plugging the injectors back in i got no popping just crank crank crank...
the car did run before the engine was out, well electricly anyways lol
91 TSi- Hates Me
LOL You mad bro???
Old 08-14-2009   #18
john
Business as usual
john's Avatar
Have you checked for spark and fuel yet???
It has been a while for me but that plug looks like the oxygen sensor. My car is out in Shakopee so I can't go and check though.
97 Viper GTS
Old 08-14-2009   #19
95talonracer
Finally Tuned...
Drives: Spyder GSX
I am guessing the timing is off. You may think its on but double check again with the cover off. It sounds like it may be off by a few teeth or something.
Amsoil Dealer
Old 08-14-2009   #20
OMGkiwi
Drives: 91 TSI
I dont think its an o2 sensor, its on the drivers side right by the coil pack.
when I checked for compression, I checked for spark while the plugs were out, spark is good and strong. I will double check the timing, but the top cover is off and the timing marks line up perfectly, ill throw a screwdriver down the #1 spark plug hole just to make sure its tdc
thanks for the help guys
91 TSi- Hates Me
LOL You mad bro???
