Old 08-31-2009   #1
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
2500 rpm knock//clack, starion
So this is for the starquest gurus on here, this same question is on SQC too but I need fast help.
The first diagnosis was a loose balance shaft chain, as it had in fact loosened up and chewed up the guides, replaced the whole lot, inlcuding timing chain, and balance shaft chain, and all guides, and sprockets, and tensioners.
we still have the 2500 rpm knock, i also checked out the main bearings but not rod bearings, I didnt assume it would be rod knock, but could it be? it sounds more like trying to stab a front case with a screwdriver than a knock.
Old 09-01-2009   #2
Re: 2500 rpm knock//clack, starion
rod knock.
Old 09-01-2009   #3
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
even when it is only audible above 2500 rpms? I always thought rod knock was a constant thing, like when my talon had it, and the taurus I have now has it. Those are consistent, and go with engine rpm, this is neither.
Old 09-04-2009   #4
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
It depends, last G54b that spun a bearing on me wasn't audible till 3000rpm,
give me a call if ya like,
Jesse
651-204-7040
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
