Old 10-22-2009   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
its alive again !
i picked up a 91 talon a few weeks back and its been a fun ride until things go boom i bought it running with spun rod bearings the head was still good so i picked up another engine another 7 bolt and it was ok ran find until i found out the o2 was bad and apparently ran it so lean it exploded a rod thru the oil pan all the exhaust valves are white .. so i got another engine a 6 bolt short block from grease monkey . I did the balance shaft delete.
so far had bought a gates racing Kevlar timing belt ,aem wide band, hallman es boost controller, dsmlink, meagan 3 in downpipe , fp evo 3 ,arp head studs ,boost Gauge ,oil pressure gauge, wallbro lph 255
things yet to buy are
injectors 650-1000 cc
fmic
adjustable fuel pressure regulator
cams
so this last week has been a real pain in the ass been thu 2 engines both were 7 bolts. learned my lesson about those . 6 bolts are where its at
got it running today at 4:40 pm it had a heart beat ...
now its all tuning witch i am new to so i think ill wait and have it done some where and watch them do it ... unless some one want to help me out and have some fun ...
ID:	9341   Click image for larger version
ID:	9342   Click image for larger version
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 10-22-2009   #2
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: its alive again !
pretty cool man. get a video up if possible!
ლ(ಠ益ಠლ)
Old 10-23-2009   #3
boredfatguy
Drives: 94 Eagle Talon TSI
glad you got it up and running, that was fast i just got that ecu from you the other day haha
First DSM Project:
1994 Talon TSI
Small 16g
2g MAF
550cc Injectors
190lph Fuel Pump
ACT 2600
boredfatguy is offline   Reply With Quote
Old 10-23-2009   #4
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Go to Shane at DB, it is $ very well spent!
Amsoil Dealer
Old 10-23-2009   #5
way2fastalon
IS Broken :-/
please excuse the grammar and punctuation
wow all i can say ... i just got done taking it for a test run running dsmlink figering out how to tune the thing well i got it some what figured out on how the fuel trim works - adds fuel + less watching my wide band closely im getting 11.8 at wot id like to see 12.4 to be on the safe side did a few pulls and they were strong hitting like 17psi boost ! i hope that's good wondering if 20 is possible with 450s im running it in open loop got it to idle ok got good vac cum about 18.5 19 at idle i think it need a coolent temp sensor i cant get it to read ... ill do more tuning tomorrow as far at db goes ill be going there as soon as i can to get it done right ..
+more mods to list
Old 10-24-2009   #6
4seasons69
4seasons69's Avatar
you want an 11.0:0 af ratio not a 12.4. a 12.4 is very lean for a dsm
Old 10-23-2009   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
I guess I dont get why you would have a 7 bolt in a 91 talon in the first place...
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 10-24-2009   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Are you running E85 or pump gas? If pump you want 11.0 like 4seasons said. If E85 12.4 will be fine. Make sure you watch your IDC (injector duty cycle) With a 16g at 17psi your 450's are probly maxed out. What does your timing look like?
-1990 Mitsubishi Cyborg 4WD-
Old 10-24-2009   #9
way2fastalon
IS Broken :-/
tuning it now
my timing peaks out at 36 degrees im going to keep timming down i think 34 is all most too much im not running e85 yet running 93 octane btw i thought on the scale for lean and rich 20.0 as in being ritch at hell and 10.0 lean as hell is that right ... ? on dsm link it says im getting a 11.5 -13:4
+more mods to list
Old 10-24-2009   #10
way2fastalon
IS Broken :-/
car runs rich when at idle if 4g63t crazy would like to come over and help out would be cool
+more mods to list
Old 10-24-2009   #11
4seasons69
4seasons69's Avatar
Re: tuning it now
is that 36 degrees timing under wot? that seems awfully high. how much knock is there? and as for the af ratio's you have them backwards 10.0 is very rich and 20.0 is very lean. on pump gas you want to tune for 11.0 (low 11's for af ration) under wot
Old 10-25-2009   #12
way2fastalon
IS Broken :-/
found out i have a bad ground on my wide band its not reading constant it only reads when i rev so i will get that straighten out tomorrow allso going to get a new temp sensor cause it reads -40 in dsmlink the code is circuit malfunction i dont get that cause it reads on the dash ? allso i am NOT running a front o2 because i want to tune it at every rpm + the one i have is bad reads 0.00 id like to tap in to my wide band o2 some how but i haven't found anything about doing that so what i was going to do it use one of the imputs to the ecu the temp pin 15 egr one to plug my wide band in to that one the the v5 out put on wide band and tune from that .
+more mods to list
Old 10-25-2009   #13
4seasons69
4seasons69's Avatar
the ect sensor and gauge are seperate that's why the gauge still works. check the wires at the ect sensor plug they may have broken. that's what happened on my car. you're better off putting a good o2 sensor in and letting that take care of closed loop for you. and tune wot ( unless you take somewhere and have it tuned). or if you have v3 just have that simulate a narrowband signal for the o2 and just use your wideband
