Old 12-11-2009   #1
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Dsm project
Asking price $2600 ( The price has changed all the issues have been fixed) OR BEST OFFER I really need to get rid of this thing ASAP
The car runs and drives. Stock swyrlys have been curbed for some 16 Inch Enkei Wheels. If no body wants to pick it up by the time i am completely finished with the car I will not be selling it any longer!
1991 Eagle Talon TSI 1G-
Modifications:
Engine:
Stock Rebuilt 6 Bolt Block (Ceramic Paint Coated)
ARP Head studs
Balance Shafts Eliminated
Red Stock Valve cover included( Be ware it is ugly) ^_^ new one would almos complete the Engine bay.
New PCV valve
Exhaust:
Ported 2G 02 Housing (Ceramic Paint Coated)
2.5" Custom Straight Turbo back Exhaust w/Magnaflow Muffler
*come with stock 1G exhaust manifold.
*If buyer is interested i have a Tubular manifold as well
Intake:
3" Short Ram Intake Pipe (Ceramic Paint Coated)
Ported MHI Evo 3 16G Turbocharger
Stock maf (3G 501 MAS included if wanted)
QPR Throttle Body FIAV Blockoff Plates
Fuel:
560CC EVO VIII Injectors ( Brand new Mitsu Dealer O Rings & Lower Injector seals)
Walbro 190 LPH Fuel Pump*
Electronics:
Eprom ECU w/Keydiver Chip
TurboSmart Boost Tee MBC
Greedy Turbo Timer (Not installed)
Drivetrain:
ACT 2600 Clutch Kit
Roller Skate Shifter Bearings
Non-Cruise Shifter Cable
Suspension & Brakes:
Option Import Front Strut Bar
Stainless Steel Rear Brake Lines
Adaptive One Front Brake Pads*
NAPA Safety Stop Rear Brake Pads*
Blank NAPA rotors
New Tie Rods Both Sides
New Wheel Bearings both sides
(Every thing is NEW)
*Does need some new shocks up front*
Interior:
2G DSM Leather Shift Knob
Exterior:
Enkei 16inch wheels complete set. (Good tread on tires)
Miscellaneous:
FIAV Eliminated
Emissions Eliminated
A/C Eliminated
Cruise Control Eliminated
Catalytic Converter Eliminated
Idle air control motor eliminated.( Unless you want to carry a screw driver everywhere you go it needs a replacement motor)
Winter Tires are next inline.
The car is getting final finishing touches.
Thank you for your time. I WILL CONSIDER ALL OFFERS.
Last edited by Alpha D; 12-13-2009 at 05:53 PM.. Reason: Status of the Car has Changed
Old 12-11-2009   #2
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
link to a few pictures: http://www.mitsustyle.com/photopost/...00&ppuser=5119
Old 12-12-2009   #3
brando
Drives: gutlass
Re: Dsm project
omg a black cherry.
is it awd?
Old 12-12-2009   #4
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
Yes, It sure is a awd Shifts nice to!
Old 12-12-2009   #5
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: Dsm project
So what does it need?
Old 12-12-2009   #6
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Dsm project
Will you please be honest with people and tell them what compression numbers the motor makes? So someone doesn't get taken for a fast one like you did
Style's automotive engineer
Old 12-13-2009   #7
Re: Dsm project
Originally Posted by Alpha D View Post
Drivetrain:
Did you mean non-cruise throttle cable?
I think he is being honest and really doesn't know the compression numbers. If it were me buying the car I would just bring a compression tester with when I went and looked at it.
Old 12-13-2009   #8
Re: Dsm project
What all is wrong with the car? What needs to be done to fix it?
Old 12-13-2009   #9
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
I will tell you every single thing that i have found out about the car. NO WAY ON EARTH WILL I BE UN HONEST! For everyone to know the number on my compression tester were 120 115 110 the last one was between 115 and 110. That in theory is very bad. We tested my friends motor it to read low way low as well. We came to the conclusion that my tester read about 15psi low. He ran another test on his vehicle with a different gauge it showed 15psi higher on all Cylinders. if you have any more questions please feel free to send me a pm.
Old 12-13-2009   #10
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
As of now nothing else needs to be fixed except for installing the new side mount intercooler i picked up today. Put in a turbo timer which i have if you want. Then you would need to get a master cylinder extension rod. ( I am sorry i do not remember the exact name of the rod needed)
-Turbo Coolant leak Fixed
-Starter Fixed
-Maf fixed have 3G can come with the car
-You might want to look for a few trim pieces.
*Notice the car Runs & Drives Now.
I have put close to $700 i am taking a Huge hit. But i really want a VR4
Old 12-13-2009   #11
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
Thank you very much s1ngletracker for making me feel even stupider then i did. I trusted a fellow member. . . . stuff happens end of story. He said he did not know about the motor. I will believe him.
I know that for some of the people on this forum the car would be a piece of cake to fix. I like the car its FINALLY DRIVABLE! After all the time money and effort into it. So please dont make it seem as if i am trying to unload my burdens on a UN suspecting person. I will post it up on Craigslist for 3k once i feel like Ripping some one of!
Old 12-13-2009   #12
Re: Dsm project
Any trades?
Old 12-13-2009   #13
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
Depends on what you have.
Old 12-13-2009   #14
Re: Dsm project
96 pontiac grand am gt, with new plugs, wires, front brakes, serp belt, tensioner etc. check engine light is on for an o2 sensor. Been my daily driver for a while now. Oh, and brand new tabs getting bought tomorrow.
Old 12-13-2009   #15
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
Sounds Like a Solid Car. Im not into Grand am's though sorry, Not interested.
Old 12-24-2009   #16
rocket2g
Drives: 2g
Re: Dsm project
What is wrong with the car now??? anything on the compression?? Idle air control motor eliminated.( Unless you want to carry a screw driver everywhere you go it needs a replacement motor).. what does this effect on the car?? running and driving?? what turbo??
rocket2g is offline   Reply With Quote
Old 12-25-2009   #17
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
If you are interested rocket send me a PM. The car does not have any problems except for one huge boost leak. I have build a boost leak tester kit. I am in need for a compressor. To answer your question quickly it has a MHI Evo III 16G
Old 12-25-2009   #18
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Dsm project
You might of missed the Build List Above refer to it incase you want quick reference as to what has been done to the car.
