Old 02-04-2010   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Thumbs down o2 housing sealing problems..
Well after I fabbed up the rest of my exhaust. I was able to hear an exhaust leak I had. It was between the hot side on the turbo and the o2 housing. I decided to take a straight edge to both of them and apparently both of them are warped. So now what the hell do I do? Double gasket?
Double gasket + high temp rtv? Take them to a belt sander?
-1990 Mitsubishi Cyborg 4WD-
Old 02-04-2010   #2
Re: o2 housing sealing problems..
If they aren't too bad a new gasket will seal the deal.
Or machine them straight, plus a new gasket. Can't cost that much.
Old 02-04-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I think I'm gonna try to double gasket. I had a single gasket in there and it definately did not seal.
Old 02-04-2010   #4
If the flange is thick enough on the 02 housing, I would take a sander to it. Just make sure that you keep it flat and straight.
Old 02-04-2010   #5
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Yea, its most likely thick enough, just put it on a sander.
'04 Honda Ricer: stock
Old 02-04-2010   #6
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
It's a quarter inch thick so it should be fine. Now I just gotta find someone with a belt sander.. Haha. What's even more frustrating is non of the holes line up very well. I had to drill them out a lot just to get it to bolt down.
Old 02-04-2010   #7
I would find some place to machine it flat, but that's just me wanting to do it the right way.
Old 02-04-2010   #8
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Anyone know a place that could do it?
Old 02-04-2010   #9
I would assume any machine shop could help you out.
Old 02-04-2010   #10
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Hmm, I'll have to look up some mechine shops in my area then.
Old 02-04-2010   #11
Belt sander and ultra copper, all a machine shop is going to do is toss it on a belt sander and charge you $40 for something you could do in 5 minutes.
Old 02-04-2010   #12
CarPsyco84
CarPsyco84's Avatar
I can sand em for ya, we got a 18" disc sander that will do nicely.
-When in doubt, Moar RPM.
Old 02-04-2010   #13
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
PM sent.
