Old 11-07-2009   #1
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Stock Parts + more
Cleaning up the garage and figured post these and see if there are any offers. PM with any questions
1g 7 bolt Cylinder Head $150 (perfect for a person looking to upgrade their 2g cylinder head)
1g 6 bolt Cylinder Head $50
4g64 block with crank $175
Stock valve cover $30
Valve cover off of hundai $40
1g stock turbo cams $50
1g intercooler $10
GM MAFT Sold
2g MAS with pig tail $30
Hard intake pipe (MAS to turbo) with hard BOV pipe $40
1g exhaust manifold (surprise no cracks) $10
1g 6 bolt turbo oil pan $20
Turbo heat shield $10
1g K&n air filter $25
DIY Coil on Plugs (4 of them) each come with pig tales for wiring them up. Doesn't include plate but that should be easy to make for a DIYourselfer $30
*Added
AN fitting for oil pan. Bolts right to the oil return line entrance on oil pan. NEW! With bolts. $20
FWD Flywheel 6 bolt BO
Roll Bar- should fit in the back of any 1g DSM and all it would take is a little welding. Just haven't had the time to install it. $100
Pics soon to come...
Old 11-07-2009   #2
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
Re: Stock Parts + more
Pix!
Old 11-07-2009   #3
Andrew7dg
Andrew7dg's Avatar
http://s217.photobucket.com/albums/c...%20For%20Sale/
pictures of stuff forsale
Sorry about the mess in the garage. I took them really quick
Can answer questions about parts
Old 11-08-2009   #4
turboimports
Valve cover have any cracks? 4G64 a 6-bolt?
Old 11-09-2009   #5
Andrew7dg
Andrew7dg's Avatar
Valve cover has no cracks, It looks really good. It is just dirty and needs to be cleaned. like most of the parts that I have...
The only 4g64 blocks I pick up are 6 bolts. 7s are way too easy to find...
Old 11-10-2009   #6
gsxer
ill take your long rubber intercooler pipes from your intercooler how much
PM me
gsxer is offline   Reply With Quote
Old 11-11-2009   #7
gsxer
bump waiting for pm
Old 11-28-2009   #8
turboimports
Pmd back again. Need phone.
Thanks.
Old 02-11-2010   #9
Andrew7dg
Andrew7dg's Avatar
Bump! plus prices lowered
Still need to clean out garage.
Making room for another motorcycle
Prices are Best offer so don't be afraid to shoot me prices
Old 02-12-2010   #10
The GM MAFT is that the Translator box? or is that the GM MAF?
Old 02-12-2010   #11
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Did you find a good deal on a V-Max?
Old 02-17-2010   #12
Andrew7dg
Andrew7dg's Avatar
Dude, sorry I haven't been keeping up to date with these...
I have the box and the GM MAF (I have two MAF)
*Just to note, I lengthened the wires on the MAFT so that it wouldn't sit inside the engine bay. I have heard that the box isn't weather proof and that keeping it inside is the way to go with these. You will need to reconnect the wire once the wires are run to where they should be*
Originally Posted by turboimports View Post
Does 2.4 block come with front case, etc.?
Its a dirty block but a good block
I cut the timing belt to get the head off.
It is just a stock block out of a hyundai. You would have to get pistons if you want to make it a low compression block.
I have to make room for a V-max!!!
that is the next bike for me!
Old 02-13-2010   #13
turboimports
Old 02-18-2010   #14
Andrew7dg
Andrew7dg's Avatar
Added some parts.
I just realized that I didn't have any pictures of my MAFT there are a couple of people here interested in it
I would like to sell it as one kit
MAF-T ($50)
GM MAF ($15)
Couplers with clamps ($25)
$90 all together
The other item added is a Blitz blow off valve with pipe or flange. Loud BOV
They want usually $200 for this new! $100?
Old 02-21-2010   #15
way2fastalon
IS Broken :-/
way2fastalon's Avatar
PMD on 4g64 block
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 02-21-2010   #16
If that 2.4 is out of a Hyundai, it's a G4CS, not a 4G64. Both are good.
Old 02-22-2010   #17
Andrew7dg
Andrew7dg's Avatar
I had both. But thanks for pointing that out. The Hyundai Block is sold!
I am sitting on the 4g64 till I know the Hyundai block and crank are up to builders speck. I just want to make sure that he is getting what he paid for.
Old 02-24-2010   #18
Andrew7dg
Andrew7dg's Avatar
The MAF-T is sold
