Old 02-19-2010   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
New modification
I picked up a 90 turbo FWD laser and have found a few interesting things on it. The pics below show what to do if your upper i/c pipe is flanged for a tial BOV and you don't have one.
Step 1- Find a piece of hose you can fit around the tial flange
Step 2- Tighten the hose over the tial flange and attach it to the stock hard pipe with a stock BOV
Step 3- Go to Menards and buy a rubber cap for the other end of the hard pipe. Install it.
Step 4- Use a piece of radiator hose to recirculate the BOV into the intake. Use a zip tie to ensure the hose it tight
ID:	9772   Click image for larger version
7/25/09
Old 02-19-2010   #2
Re: New modification
will it fit under the hood?
Old 02-19-2010   #3
hahah. Did it leak? That's some pretty impressive craftsmanship
Old 02-19-2010   #4
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
zip ties FTW!
Old 02-19-2010   #5
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
The BOV mount is downward so it was sitting just above the tranny . I didn't even bother to see if it leaks. It was clamped down pretty well, so I am guessing it probably functioned ok.
The car drove on and off the trailer ok, but I haven't done too much with it yet. I need to pull the ebay 16g off of it and am not sure if I will throw a 14b or 16g on it yet. Didn't even try using the ebay turbo. Found out what is was when I was pulling the nice BOV setup off.
7/25/09
Old 02-19-2010   #6
Wow, engineering at it's finest.
Old 02-19-2010   #7
wanna trade the ebay 16g for my 14b? lol
Old 02-19-2010   #8
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Tom, I don't think you would want the ebay 16g. From what I have heard, they are all garbage. I wouldn't test it with your new motor. I would trade it to you, but I think I would probably be ripping you off.
If you are interested in the fine piece listed above, I will give you a good deal
7/25/09
Old 02-19-2010   #9
zip tie racing woowoo!
Old 02-19-2010   #10
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
Probably used the zip tie because he lost the other radiator hose clamp.
7/25/09
