Old 06-13-2010   #1
blackrosenova400
blackrosenova400's Avatar
Pte 6131 For Sale
Here is a Pte Scm6131 (620hp rated) for sale. Is is currectly pulled because of a piston wrist pin failure. Turbo had no shaft play. Installed brand new bearings anyways for good insurance. Turbo is in perfect condition and has a 360 thrust bearing system for high boost.
The S cover has a 4 inch inlet and a 2.5 outlet.
Oil it correctly and it will treat you well.
460$
20g Mafia
Old 06-13-2010   #2
Re: Pte 6131 For Sale
Pretty sure that's not an S cover. I don't see any anti-surge ports.
Old 06-13-2010   #3
Not all S-covers have anti-surge ports. My old 6776 didn't have any. e-cover has the "bumps" in the castings, and is a 2" outlet, s covers are 4" in, 2.5" out, and h covers are 4" in, 3" out.
Good luck with Sale chad, I can vouch this turbo has NO shaft play, and pulls hard as hell on his car.
Hughes, the post was in cleaning up confusion for the seller. Before you ban me, read, and either delete the posts above, or leave it be.
Old 06-14-2010   #4
blackrosenova400
Thanks Swifty for the clarification.
Thanks for nothing Kevin, what a useless post.
Im kidding your just looking out for everyone else
20g Mafia
Old 06-15-2010   #5
Thanks for the clarification Swifty. I just thought all S covers had anti-surge ports.
Old 06-15-2010   #6
blackrosenova400
I used to think that too, just because what the heck does the S stand for?
Special?
Lol...
You can tell its an S cover because of the Aspect Ratio of the cover. This cover says A/R .70 while an E cover will say .63
Also I recommend not using the internal wastegate and going with an external. I will weld it for free for use with an external wastegate.
20g Mafia
Old 06-15-2010   #7
E cover - usually 3" inlet
S cover - usually 4" inlet
SP cover - usually 4" inlet with surge ports.
Hope this helps.
