Old 08-12-2010   #1
Brandito93
Brandito93's Avatar
Drives: 1989 Nissan 240SX RB20
Send a message via Skype™ to Brandito93
Single Turbo vs. Twin Turbo
This may be the stupidest question ever but if a twin turbo engine is tuned to lets say 14psi and a single turbo engine is tuned to 14psi. Would that be like tuning the single turbo engine to 28psi to match the performance? If someone could explain how that works it would be greatly appreciated.
Brandito93 is offline   Reply With Quote
Old 08-12-2010   #2
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
Re: Single Turbo vs. Twin Turbo
No...
Are you saying that there is a TT engine @ 14psi, the single turbo engine @ 14 psi and a single turbo car at 28 psi, it'd be the same hp as the other 2 (14psi cars) power wise?? If so...it doesn't work that way. There are ALOT of factors that come into play with this kind of question.
ლ(ಠ益ಠლ)
Old 08-12-2010   #3
Brandito93
Brandito93's Avatar
Than explain, I don't get it. Sorry I'm car stupid, but at least I know a shit ton more from when I first got my car. But is it a legit question or am I just super retarded?
Old 08-12-2010   #4
awd-drifter
'2of9'
Gotta start somewhere. It's not a legit question because it's not really that specific of a question. It is sort of retarded lol. but hey, like i said, you gotta start somewhere. In the automotive world twin/single turbo has it's pros/cons depending on your build/application BUT having a 1g DSM at 14psi compared to a Supra TT @ 14psi is totally different from an Evo @ 28 psi.
ლ(ಠ益ಠლ)
Old 08-12-2010   #5
Brandito93
Brandito93's Avatar
ok
14 psi single turbo talon >greater than or equal to< 14 psi twin turbo vr-4
i guess basically what im asking is, what is the difference in turning up boost on a single turbo vs. a twin turbo.
Old 08-12-2010   #6
awd-drifter
'2of9'
ok
14 psi talon >greater than or equal to< 14 psi twin turbo vr-4
4 < 6. Obviously, there is more air going in/out in 3/S's compared to DSMs. 14 psi in a DSM is much more different than 14 psi in a 3/S.
ლ(ಠ益ಠლ)
Old 08-12-2010   #7
Brandito93
Brandito93's Avatar
ok, ill just leave it at that. I'm confusing myself.
Old 08-12-2010   #8
14psi is 14psi, but 600cfm of air at 14psi is going to make more power than 400cfm of air at 14psi. That's how you need to look at it.
Old 08-12-2010   #9
awd-drifter
'2of9'
x2
ლ(ಠ益ಠლ)
Old 08-12-2010   #10
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
It also makes a difference whether the TT set-up is Sequential or Parallel.
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 08-13-2010   #11
CarPsyco84
CarPsyco84's Avatar
way to make it more confusing...
14psi on 2 turbos is the same as 14psi on 1 turbo, the differences are from how well the air flows into and out of the engine, that cfm thing. There's a whole bucket full of reasons to do TT vs single and vise versa. Some of the common reasons are the fact that twin turbo setups on like a V6, you can use 2 small cheap turbos and make good power, have a short route to the turbos, and twins tend to spool up faster than a comparable single. Problems though are twice the pluming, and twice as many moving parts that can fail or leak. And probably the most important reason is the logistics of making it all fit, usually the reason to do one or the other in the first place.
-When in doubt, Moar RPM.
Old 08-13-2010   #12
Read up:
http://mitsustyle.com/forums/showthread.php?t=22320
