Old 08-04-2010   #1
Chim55117
Drives: 2007 BMW 335i Coupe
VR-4: No Spark + No Fuel = No Start
Last night I was driving the VR-4 near the car dealership strip in my local area, and it suddenly lost both fuel and spark and came to a stop. I tried starting it, and it restarted, but roughly, and then it died and won't start now. If you crank the key, you can hear the starter turning over, but there is no spark or fuel. I had the car towed home, and it's sitting in my driveway. At this point I have no idea what it could be, I checked my MPI fuse and relay and they are good. Does anyone have any ideas? Thanks in advance!
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
Old 08-04-2010   #2
Gravy
Who's this guy?
Re: VR-4: No Spark + No Fuel = No Start
ECU?
Old 08-04-2010   #3
Chim55117
Originally Posted by Gravy View Post
ECU?
I pulled it today and it looks fine, no visible signs of acid, and my older brother who owned the car prior noted that it was rebuilt about 1 year ago.
Old 08-04-2010   #4
Gravy
Who's this guy?
If i'm not mistaken, the the CAS will still let the fuel pump come on?
Old 08-04-2010   #5
blackawdtsi
Drives: 2G DSM
CAS
Old 08-04-2010   #6
blackawdtsi
Drives: 2G DSM
Might also be TPS
Old 08-04-2010   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
TPS has nothing to do with having spark or fuel. The CAS would cause no spark. Fuel would be controlled by the relay. How exactly did you check the relay? Can you hear the ECU turning on? Power transistor connector plugged in and tight?
-1990 Mitsubishi Cyborg 4WD-
Old 08-04-2010   #8
twack
It was a auto get over it
twack's Avatar
t to be simple minded but did you blow a coupler off?
Old 08-04-2010   #9
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
How would that cause no fuel or spark?
You are sure that you have both no spark and no fuel? It is wierd to loose both. Did you try swapping an ECU?
How is your timing belt? If it broke you will have no Cas input and it could've taken out your crank sensor
Old 08-04-2010   #10
aaronspeed
Drives: 1991 Eagle Talon AWD
CAS also controls the fuel pump. The pump gets a signal from the CAS to turn on and off. Does the VR4 have the bypass harness on the firewall like the 1g to test the pump. If the pump works then I would loosen the CAS and rotate it left and right and hear to see if the fuel pump cycles. If you don't hear the pump then borrow a CAS to test or use a Multi-Meter and test the CAS like listed in the repair manual.
aaronspeed is offline   Reply With Quote
Old 08-04-2010   #11
i have a spare 1g cas if you need to borrow it for troubleshooting purposes.
Old 08-04-2010   #12
T is for TURBO
Drives: A car
The starter cranks normally, but the engine won't start - At least you know that the starter is working. If the starter cranks but the engine won't start, there could be wide range of problems. Here are some of the most common:
- Problems with fuel delivery system (e.g bad fuel pump, fuel pump relay, clogged fuel screen, etc.)
- Problem with engine electronics (e.g crank sensor, cam sensor, air flow sensor, power relay, engine computer, etc.)
- Ignition system problems, especially on older vehicles with the distributor (e.g bad ignition coil, commutator, rotor, distributor cap, etc.)
- Defective ignition switch
- Problems with vehicle security system
- Internal engine problems (e.g broken timing belt or gear, low compression, etc.)
T is for TURBO is offline   Reply With Quote
Old 08-04-2010   #13
A engine needs 3 things to run: fuel, spark, and compression. I would test for spark, test to see if the injectors are firing, and do a compression test. Did you run out of gas? does the ecu smell like dead fish or burnt electronics, I would swap the ecu out for a known good ecu. Test the MPI relay, this turns everything on, fuel pump and ecu.
Old 08-06-2010   #14
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
It is the CAS...
