Old 07-13-2010   #1
way2fastalon
IS Broken :-/
way2fastalon's Avatar
how do cam shaft dowl pins snap .. ?
so we were driving along and and its making the usual 1g lifter tick and something else starts making noise were like what is that i thought it was a bad rocker but the engine ran fine ... but then... we tried to limp it home and it quit running ..
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 07-13-2010   #2
Re: how do cam shaft dowl pins snap .. ?
I'm assuming the dowels that the gears slide onto. My guess is that they were improperly installed.
Old 07-13-2010   #3
Dowel pins are just for alignment when installing, if the cam gear bolts are properly torqued they are not needed to keep the cams in time. A snapped one could be a number of things including improper installation of the pin, improper installation of the cam gear on the camshaft, an incorrectly torqued cam gear bolt, or just a defective pin from the get-go. If a stock pins fails after 20 years though, that could just simple be fatigue.
Old 07-13-2010   #4
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
must not have torqued the cam gear bolt down all the way and the gear spun on the cam and snapped it.
-1990 Mitsubishi Cyborg 4WD-
Old 07-13-2010   #5
way2fastalon
IS Broken :-/
ill take some pictures ... sounds like all valves on the exhaust side are done ... no compression btw this engine has 250,000 miles on it with regular oil changes with mobile 1 syn 15w40 i was hoping to make it to 300,000 on it before something went wrong .. lol
+more mods to list
Old 07-14-2010   #6
mlomker
*Resting In Peace*
mlomker's Avatar
Is that all? I thought my beater at 150 was doing well.
Old 07-24-2010   #7
CarPsyco84
CarPsyco84's Avatar
Camshaft could have seized too, hard to tell exactly till its all apart. Then its usually painfully obvious.
-When in doubt, Moar RPM.
Old 07-25-2010   #8
way2fastalon
IS Broken :-/
here are the pictures
+more mods to list
Old 07-25-2010   #9
The cam bolt loosened up, if the bolt is torqued properly it is the friction surface of the cam gear and cam that keep everything in line. This is a case of if you have an engine still running after the factory warranty or a ton of miles it might be a good idea to check everything over.
Old 07-28-2010   #10
way2fastalon
IS Broken :-/
the funny thing is the cam's where never touched ... all stock just did the t belt changes every 30,000
+more mods to list
Old 07-28-2010   #11
santa
Boost Spike
santa's Avatar
No red lock tight used on cam bolt ftl!!
