Old 08-03-2010   #1
TsiEagleTalon92
TsiEagleTalon92's Avatar
Drives: 2022 Hyundai Palisade
Stock crank pulley size?
Anyone happen to know what the size of a stock crank pulley would be? The one that was on my car that I can no longer use was a 5 to 5.5 in pulley. I need to find a new after market on that doesn't squeak or just a stock one that someone would let me buy.. That and I need the part the timing belt wraps around and also the oil pump. (massive brain fart on those names at this time)
Off topic Q. Are the zero tension blue or purple timing belts worth the $$?
TsiEagleTalon92 is offline   Reply With Quote
Old 08-10-2010   #2
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Re: Stock crank pulley size?
Stick with the stock one on a street car. The crank pulley is there to dampen the harmonics. You can put in a 1g or 2g. My 1g crank pulley went bad and I just swapped in the 2g crank pulley. There is a small weight difference with the 2g being a little heavier, but it appears to be built better.
Old 08-10-2010   #3
TsiEagleTalon92
I don't have any harmonics. I'm just looking to see what the stock size is in comparison to what was on my car.
