Old 07-29-2010   #1
Can a 1G handle? Seriously.
I want my 1G to handle good, with that said I know its no evo or miata, but something where it wouldn't make someone cry if they tried to corner with it.
My last 1G had a rear sway bar only and it really flattened out around corners it felt really good.
The car also had 235/45/17s and the rear subframe had urethane bushings.
My questions are about tire size, I was thinking about going to 16s if I get rid of these wheels, but will the taller sidewall decrease the handling.
Matt d. said it wouldn't feel as responsive, so I'm looking to stick 17s.
Is the suspension geometry/hardware just too old/shitty styled to not handle well.
I want to replace every last bushing in teh car in order to make it handle/feel good.
Thanks
Aaron
Old 07-29-2010   #2
Re: Can a 1G handle? Seriously.
Any car can handle decent, but you need to start at the base and work up. That base is tires. What you get is up to you, but the top street tires at the moment are Dunlop Direzza Z1 Star Spec, Kumho Ecsta XS and Hankook RS-3.
As equally important as tires is alignment. Get yourself a degree or two of negative camber in front, a negative degree in the rear, and you'll have a car that is more responsive than you thought was possible.
Beyond that, you need to look at springs and shocks. DSMs have a good assortment of shocks to choose from, and if I were you I'd just mate a good set of adjustable shocks with some good springs.
Beyond that, a bigger rear swaybar will help the car rotate in the turns, and adding a front swaybar will add more overall grip but help keep the car neutral while turning.
If you're feeling really crazy you can start putting in polyurethane bushings all around. Old cars make more use of this than newer cars, but it's the last thing I'd do, especially if your suspension isn't sloppy.
Old 07-29-2010   #3
Matt D. pretty much said everything I was going to. An alignment is like a tune, so important yet so often over-looked. The 1G chassis has a ton of flex so a few simple braces (such as front and rear strut tower bars) can make a noticeable difference.
Old 07-29-2010   #4
Oh yeah, forgot about those.
Old 07-29-2010   #5
Tachyon
Tachyon's Avatar
Drives: Icarus
You know, I was researching this quite diligently the other day, trying to find a few tricks or more obscure facts about the 1g suspension and its optimal setup. During the course of my evening I ran across a series of posts by Dennis Grant verbally stating that he could setup a SN95 mustang chassis to handle better than our 1g's. Ouch. Something about the rear toe-in being horribly wrong from the factory… There were some things that could be done, but the threshold with the stock geometry was quite limited, and would ultimately be the ceiling.
-Sebastian Vettel
Old 07-29-2010   #6
Yes, if I recall correctly the rear suspension will toe in as the suspension compresses, has to do with the whole trailing arm design.
Old 07-29-2010   #7
Yup, you should of seen the toe on my 1G that I lowered...
Old 07-29-2010   #8
Thanks guys I really appreciate it.
I have some decent HP all seasons, but i have some dunlop direzzas to go on once its time to play.
I plan on picking up a rear active toe eliminator which should make the car more predictable.
Old 07-29-2010   #9
I've got a set of the toe eliminator SS bushings, I'll be putting them in myself when I get to it. It is a big problem on 1G, especially now that they're mush like mine are. BTW, there's been a few threads on this on other boards and the consensus, most from Dennis, was that Koni Yellows with Hypercoil springs and some adjustable pillow tops were the best handling option out there. He had nothing good to say about any of the coilovers, especially the K-sports.
Old 08-01-2010   #10
95tsi
95tsi's Avatar
Drives: a pos
True story, they work great on my 2G!! I just had to ditch the upgraded rear sway bar due to it being too tight and over steering. If you can get Bilsteins I wanna say they have a better shock rate than the Koni's but you might wanna double check that. Sure would be nice to have some camber adj like you 1g guys!!
Old 07-29-2010   #11
Oh, and the poly bushings are probably the best overall mod unless you've already replaced all the bushings, they're all rotted by now.
Old 07-29-2010   #12
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
Steve, is the Jay Racing Active Rear Toe Eliminator Kit what you're talkin about?
http://www.jayracing.com/index.php?m...roducts_id=207
Old 07-29-2010   #13
Yeah, that's a newer version of it, very nice. I've got the old Taboo speed shop ones, he's been out of business for years. Shows you how fast I get around to these projects.
Old 07-29-2010   #14
viridionplague
having owned a 94, sn95 cobra. i can vouch for ford fucking up that suspension design, and toe being a huge problem.
Old 07-29-2010   #15
What these guys have said.
But yes, these cars can and do handle well set up decently. I've enjoyed my 1g at BIR, awd is fun.
Old 08-03-2010   #16
Could I use my Ksport upper front camber plates with an aftermarket shock?
My 1G AWD is very low, the rear toe and camber is HORRIBLE.
Old 08-03-2010   #17
Sure, if the bolt pattern is the same.
Old 08-05-2010   #18
They have adjustable control arms now for rear camber. My lower ones are shortened and welded back together 90's style.
Old 08-05-2010   #19
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
K-sport upper plates have aluminum hats that are sized for small dia. coil springs. I think you would need new hats machined.
Old 08-06-2010   #20
bertrenolds5
bertrenolds5's Avatar
Drives: 91 eagle talon GST
I have stock KYB gr2 shocks with prothane bushing everywhere and motor mounts and and strut bars and my car feels like a go cart around corners. If only it were faster now!
