Old 05-20-2011   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
Throttle Body Question
Is it safe to loop the coolant lines going into the throttle body? i didnt know they needed to be cooled.. can someone explain why there is coolant going through the throttle body??? i have a 97 mitsu eclipse 4g64/4g63 head awd. Thanks!!
SpyderGSX07 is offline   Reply With Quote
Old 05-20-2011   #2
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Throttle Body Question
Its for cold start in winter to get your car warmed up faster. You can loop it and be fine.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-20-2011   #3
SpyderGSX07
ok thanks!! and thanks kerry for explaining it to me!!
Old 05-20-2011   #4
When I did this I started getting idle surge because the FIAV (reason for the water lines) stopped working correctly. Once I blocked off the FIAV it was fixed.
Old 05-20-2011   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I too had idle issues! Hooked them up and idled way better!
Old 05-21-2011   #6
SpyderGSX07
FIAV? and i did already loop my heater core.. i pulled all that HVAC stuff out.
Old 05-20-2011   #7
Yep no problem looping them, hell I even had my heater hose lines looped at the end of my dsm days!
Old 05-21-2011   #8
FIAV = Fast Idle Air Valve. It's on the bottom part of your throttle body
Old 05-23-2011   #9
Stop being a cheap ass ghetto DSMer. Get a FIAV blockoff plate.
Old 05-23-2011   #10
You looped your heater core? Wtf is the point? Some drag car spyder? Won't you get cold on top down summer nights? If you're gonna loop the lines, you might as well pull the heater core, reduce weight...
And if this is some drag beast machine, get a real throttle body.
Old 05-23-2011   #11
If you loop it, you should put on an FIAV blockoff plate on it. Or else you will be letting a small amount of air passed the TB plate all the time, which was only meant to be during warm-up.
Old 05-23-2011   #12
You could just machine a plate plate and block off the whole bottom of the throttle body. It wont idle at all cold and you have to keep your foot on the gas until it is warm but you could make a whole block off plate yourself if you're cheap.
Old 05-27-2011   #13
SpyderGSX07
the heater core is pulled... again.. i pulled all of the hvac shit out. blower motor.. evap. HEATER CORE... and all of the plastic pieces with it all.. there is NOTHING under the dash. and there wasnt any point in having the heater core in. the blower motor wasnt working. so the heater core would basically heat soak and be pointless. as for the throttle body?? im leaving the coolant lines run to it. no point in having my car run like shit until it warms up because i wanted to loop some lines..
Old 05-27-2011   #14
Good to hear about the keeping the lines to the TB.
Curious why you didn't just replace the blower motor and have heat?
Old 05-27-2011   #15
SpyderGSX07
because i didnt want to deal with the wiring problems. i didnt see it worth it. its a convertible.. i dont drive in the rain, winter, or cold. its not my dd. its my "project" car. so i said efff it im pullin it all out.
