Old 06-08-2011   #1
talonite
talonite's Avatar
Drives: 1997 Eagle Talon TSI
cutting out AFTER load
hey guys I am stumped here and kind of looking for a place to start. Just today my car started hesitating/stalling, almost like the fuel was cutting out. And i can recreate it, it only happens after i boost, it will do fine during boost and fine driving normally. But after a pull it will start cutting out when just driving normal for about 3-5 minutes, then it will go back to normal. Did a boost leak test and its all good except for a very small leak from the throttle body, but it had that before this started happening.
talonite is offline   Reply With Quote
Old 06-14-2011   #2
talonite
talonite's Avatar
Re: cutting out AFTER load
Well i have no DTC. But i am definately looking into the sensors anyways.
Old 07-04-2011   #3
talonite
talonite's Avatar
well thank you for the tip on that, it was infact the TPS sensor. DSM link didnt see a reason to throw a code though..o well. Thanks again
Old 06-08-2011   #4
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
I had an issue with my VR4 that it was cutting out just into boost and seemed like it was hitting fuel cut too. Turned out to be my TPS. But it also threw a DTC. Might be something to check out though.
