Old 06-17-2013   #1
M1L3S
M1L3S's Avatar
Drives: 99Gst
Exclamation 99 ecu tuning?
Has anyone had much luck with this method ?
I need a base map put down so I can break in the new motor. But im at a complete loss
M1L3S is offline   Reply With Quote
Old 06-17-2013   #2
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 99 ecu tuning?
Text me I know a guy.
Old 06-18-2013   #3
Fran05
Drives: DSM
Re: 99 ecu tuning?
DSM Link
Old 06-18-2013   #4
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Re: 99 ecu tuning?
Yes people have, it is a very easy and cheap tuning platform. It can do as much if not more than link. Check out dsmtalk.com and the dsmtunners.com write-ups on it. Ceddy on tunners wrote tons of programming for it. the flashable ecu's are able to do so much it is insane, you just have to read.
mitsukid124 is offline   Reply With Quote
Old 06-18-2013   #5
mitsukid124
Re: 99 ecu tuning?
Here are some links:
http://www.dsmtuners.com/forums/evos...shing-faq.html
http://www.dsmtalk.com/forums/showthread.php?t=205706
http://ceddy.us/
Those should get you all the info you need. Plus there are people that are continually helping on those two threads.
Old 06-18-2013   #6
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
http://ceddy.us/
Thank you !!!!!!!!
Old 06-28-2013   #7
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
Anyone local tuning there flashable ecu ?
Old 07-02-2013   #8
DSM-is-LOVE
Dream Motors All Day!
DSM-is-LOVE's Avatar
Drives: 03 Evo VIII
Re: 99 ecu tuning?
evoscan. Used that on my 99 Spyder GS-T. Fully flashable stock ecu. That's what Shane used when he tuned my car at the time.
2003 Evo VIII
aka Lucy
Old 07-02-2013   #9
RS98GSX
RS98GSX's Avatar
Drives: White on White 98 GSX
Re: 99 ecu tuning?
I did it on my 98 GSX!
RS98GSX is offline   Reply With Quote
Old 07-02-2013   #10
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
Would you be willing to give me a hand tuning mine ?
Old 07-03-2013   #11
Re: 99 ecu tuning?
Bring it to Shane, DB is like 10 minutes from you
Old 07-03-2013   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 99 ecu tuning?
Shane's booked solid till end of July
Old 07-03-2013   #13
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
Thats the issue im having. I just want to drive her ............. db is definitely booked solid, and I just need a street tune so I can drive it.
Old 07-03-2013   #14
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 99 ecu tuning?
Stock injectors and ecu. Stay out of boost. That's why I went with link more people to help tune
Old 07-03-2013   #15
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
Im already tuned on e85, but I swapped alot out and removed c.a.s. to clean head. So I need a re-tune. Is there a way to zero out the c.a.s. to know its timed right ?
Theres got to be someone local who can help me out
Old 07-03-2013   #16
bigboostingst
bigboostingst's Avatar
Drives: AWD Spyder
Re: 99 ecu tuning?
You can easily set your CAS with nothing more than a simple timing light.
Old 07-03-2013   #17
Re: 99 ecu tuning?
I haz a timing light haha. I also have all the ceddy maps.
Old 07-03-2013   #18
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: 99 ecu tuning?
Im hearing all these amazing things about the flashable ecu, but I cant find anyone local who has tuned theres, and has the ability to do so for othiers .........
Old 07-03-2013   #19
Re: 99 ecu tuning?
They all bring their cars to Shane!
You should set the timing before bringing it in to get tuned anyways.
I know in link there was a box you could check to lock timing in then you just moved the cas to get it dialed in. Not sure of you can do that with what you're using otherwise I believe there is a pin on the firewall you can ground that will do the same thing.
Old 07-03-2013   #20
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: 99 ecu tuning?
If you are using the stock 99 CAS it is not ajustable. If you are using a 1g CAS ground the pin on the firewall and set the timing. What have you changed since your last tune? as long as you are using the same MAS and injectors your tune should be close enuf to drive around at low boost.
11.35 @ 120mph
