Old 03-10-2021   #1
I finally have another Mitsubishi...yes this is my old stealth
Well I bought it back last weekend.
After selling it roughly 12 years ago I bought it back from the guy I sold it to. It came complete with everything I sold with it.
Acquisition and drive video:
https://youtu.be/qhv4Ps35tuc
So why?
The Corvette has hit the point to where I don't want to go much further and ruin it's street car"ness"
I feel like I have unfinished business with this platform.
The plan?
Assess parts conditions and start to acquire parts end of 2021. I need to build my shop this summer first before I tear it apart. Right now the car is loaded up with parts that I sold with it. I'll probably start with the PTE 76mm GTS single that came with it.
The parts?
76mm single to start, bigger later once I shake out the bugs (I expect the turbo to get me into the 9's)
E85/98 fuel to start
6g72 based engine
AWD Auto transmission
Proper suspension/drivetrain/tires
Keep the chassis as light as possible (for those that don't know this has a 8.5 second NHRA certified cage in it).
The goal?
Get kicked out as the cage isn't certified enough. I want to put this car well into the 8's, maybe better as time progresses. No rush but there isn't constraints on this car.
Do it right, do it proper, don't be a cheap ass. This is the new money pit.
Anyone need any 3s parts? I've got a few parts transmissions and a complete one, some stock engine parts, transfer case stuff that I know I won't be using.
Name:	Stealth aquisition intro picture edited.jpg
ID:	17399   Click image for larger version
Old 03-10-2021   #2
Re: I finally have another Mitsubishi...yes this is my old stealth
You know who to call when you're ready for some of that E98 eliteness.
Did the buyer turned seller ever do anything with it, or did it just sit there as you left it?
Old 03-10-2021   #3
Nice, Congrats! Should be fun to play with it again at this stage of life. Good luck with the performance goals, should be fun for us to watch.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 03-11-2021   #4
He didn't touch it. I still don't get it. Well I take that back, he bought a stock motor and transmission for it and then didn't touch it.
Didn't realize you were in the E98 game. I'll need barrels.
Thank you sir! It should be an adventure for sure. Hope to do it right and make it entertaining in the process. I'm excited to get started on it; but adulting takes priority and I have other projects ahead of it.
Old 03-11-2021   #5
How about a tote? Probably be easier to haul in the bed of a pickup (or on a trailer) that way. I could do $2.50/gal if you get the tote and drive up to one of my plants (Hereford or Plainview, TX).
Old 03-12-2021   #6
Re-buy is awesome, congrats! Can’t believe previous owner did nothing with it for a decade, did you sell it running condition? Any more miles on it? New plans sound amazing and also deep money pit haha. I thought it had twin 16g but that was a long time ago and my memory probably wrong.
Like one of those 300ish gallon plastic chemical cubes they use in agriculture? Dayum that’s a lot of fuel haha. I guess they are airtight but I’d be worried about water absorption over time.
Old 03-12-2021   #7
Correct, typically ~300 gallons. Really depends how quickly he plans to go through it, but 6 months to a year would be no issue at all. Moisture absorption is one of the benefits of ethanol vs. gasoline, plus it doesn't have an additive pack to go stale while sitting around.
Old 01-27-2022   #8
Man this forum is really kinda dead .
Sniffle.
Update:
Sold all the 6g72 stuff and the car actually turned me a profit. Now I'm acquiring 4g63 stuff.
Yes it's going drag 4 cylinder 4g baby.
Follow along on YouTube (please? thank you? How do you get followers?)
https://www.youtube.com/channel/UCCK...7zewunBHNQ-cjA
Old 06-16-2022   #9
Update:
AEM EMS here
partially filled o-ringed and arp'd 4g63 shortblock here
OEM crank here
Ported head with 1mm over valves here
Vband manifold here
SMIM here
2g auto awd transmission, tcases, etc.
Still need to order for shortblock:
Pistons, rods, bearings. Have assembly balanced. Assemble engine.
Longblock:
cams, gears, head studs, gasket
Drivetrain:
Center driveshaft modification/creation (aluminum)
Swap around some axle bits to get the fronts to work.
Swap out my 5 speed diff for a 6 speed diff (here)
Fuel:
Drop tank, clean, install hellcat pumps
New lines (need to buy and install)
Injectors (need to buy)
Chassis:
Finish wiring delete. Install AEM and 4g63 harness
Misc:
Exhaust piping, intercooler piping.
It's coming along but been busy bass fishing and working on the ranch. It'll be ready for single digit 1/4 mile passes when it's ready is my motto.
Old 07-21-2022   #10
URV8SUX
URV8SUX's Avatar
Wow this is a cool build I’m looking forward to seeing it at the track. Keep up the progress!!!!!
Your goals seem very achievable have your considered other ECU than AEM?
Old 09-14-2022   #11
Oh yeah. I just got this for cheap to get the ball rolling. Not an end all solution by any means.
Project update:
Longblock parts are here or on the way.
Rotating:
Weisco 1400HD pistons
FFWD Aluminum Rods
Stock uncut 6 bolt crank
ACL Bearings
Straight cut oil pump gears, "race" rear balance shaft
Block:
1/2 filled
O ringed
Kiggly Main girdle
ARP's
Head:
Kelford 280/276 cams
Kelford springs/retainers (1030's to start)
1mm over intake/exhaust valves
SMIM with dsm throttle body
Trans:
2g Auto
3 speed conversion
Kiggly 5 friction clutch pack to start
Welded center diff
Translab shift kit with IPT mods
Kiggly Billet diff support saddle
Line pressure to the moon
Trying to find a place to shot peen transfer gears until billet ones are available to buy
T-case is getting a frontline fab brace to start. I may send out my spare to boostin for the 300m upgrade. I'll think about that stuff Q4 2022/Q1 2023 when I have a motor and trans in the car. Lots to get before that.
I have a JM Fab TiAL v band manifold here. Thinking I'll go with a Borg Warner S372 with a .85 housing or so to start the party. Keep it simple 4" exhaust side exit. Still air to water.
Twin Hell cat pumps. -10 an feed to rail. 2150's most likely for injectors to start. Will most likely convert it to COP with R35 coils.
Things still to order:
Turbo setup
Radiators/coolers
Piping
Alternator relocation kit
DSS Center shaft
Suspension
Then to do a bunch of wiring and plumbing. The rest of this month will be getting the rotating assembly balanced and the block at the machine shop to validate the line hone is still good with the girdle. Will have the crank checked of course as well.
Get a longblock together and trans put together before Thanksgiving. Hope to have that in the engine bay to really start to make some progress. Will eventually need to weigh the car so I can figure out torque converter stuff.
Old 09-14-2022   #12
Whats the axle and driveshaft solution for fitting 4g63 stuff in one of these?
GSX - 571whp/490wtq
Sienna
Old 09-15-2022   #13
A few different options. Bolt on mounts exist. Depending if you are going automatic or manual you use one of the two rear ends available in the vr4 version.
Axles work with mitsubishi components. Generally a FWD pass axle and some cup swapping to make the driver side work (assuming you are starting with a TT chassis, another route is to go with a Non turbo chassis and its a bit easier as hubs clear, but then you're fwd).
AWD - move the yoke to match the dsm driveshaft. Or talk to DSS and have a shaft made to replace the front 2.
Of course I haven't finished all this, just research. Will post my results here as the drivetrain goes in. Confident it'll work out.
Old 09-24-2022   #14
Update:
Selling the AEM. Have a FuelTech 550 here
Old 10-17-2022   #15
Mark Leasure
Mark Leasure's Avatar
Good call to ditch aem, Fuel techs are good equipment.
Assuming you are making a new harness too?
www.maperformance.com
Old 10-19-2022   #16
Yes sir. Completely new harness. Finally just finished removing all the miles of factory wiring. I'm keeping lights and power windows for the pit lanes. Everything else deleted. OEM harness to the rear, new to the front and the window motors.
Old 02-14-2023   #17
This is awesome, I remember seeing this thing on the LSE dyno.
So cool you got it back! Keep up the good work
Old 11-06-2024   #18
Well sad news. Sold the car.
Happy news.
Have a Miata I'm running HPDE in and building for Time trials and W2W.
Also went back to a LS powered asset and have a 2001 Formula in the garage.
Both are getting turbos.
Old 11-06-2024   #19
Happy news.
