Old 02-12-2012   #1
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
94 Talon 1gb
94 Eagle Talon TSI AWD
Ecmlink v.3
Stock block/head, ARP head studs, OEM composite head gasket
Balance shafts eliminated
Map EF1 Turbo w/ EvoIII turbine housing
Ceramic coated EvoIII o2 housing
2g exhaust manifold
Innovate LC-1 Wideband o2
Speed density
Walbro 255 fuel pump
FIC 1250cc injectors
FMIC w/2.5" piping
Full Apexi exhaust
Mishimoto aluminum radiator
93 trans w/EvoIII conversion
ACT 2600 clutch
ID:	12445   Click image for larger version
ID:	12446   Click image for larger version
Old 02-12-2012   #2
Re: 1g 6 bolt 4g63 tsi build
So ur the one who bought my old 1g?
Old 02-12-2012   #3
Good luck with the new shell.
Old 02-18-2012   #4
dsmghost
dsmghost's Avatar
Yup, I'm getting ready to put the motor in. What can you tell me about the harness? I saw the 1g and 2g maf/mas connectors, have you rewired the fuel pump?
Old 03-17-2012   #5
dsmghost
dsmghost's Avatar
Old 03-17-2012   #6
dsmghost
dsmghost's Avatar
So I bought a used motor, a stock 4G63T from a 91 Laser FWD. Almost had to take the door off my temporary daily driver, to fit it in.
Old 03-17-2012   #7
dsmghost
dsmghost's Avatar
Got the motor in.
Old 03-17-2012   #8
dsmghost
dsmghost's Avatar
Saving up for Ecmlink. Decided to drive it on the first snow, bad idea. All my hard work down the drain.
Old 03-17-2012   #9
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Originally Posted by dsmghost View Post
So I bought a used motor, a stock 4G63T from a 91 Laser FWD. Alomost had to take the door off my temporary daily driver, to fit it in,
You know they make trucks for this kindof hauling right? Good work on getting it running though
Old 03-17-2012   #10
dsmghost
dsmghost's Avatar
Time for a new shell, a 94 1gb. Formerly had belonged Scheides, and Goodhart. Thanks Lingling!
Old 03-17-2012   #11
dsmghost
dsmghost's Avatar
Transferring interior.
ID:	12337   Click image for larger version
Old 03-17-2012   #12
dsmghost
dsmghost's Avatar
Pulling the motor.
ID:	12339   Click image for larger version
ID:	12340   Click image for larger version
Old 03-17-2012   #13
dsmghost
dsmghost's Avatar
Towing away the crashed talon. (the right side is still beautiful)
Old 03-17-2012   #14
dsmghost
dsmghost's Avatar
The talon waits for its heart transplant. The next time it comes out of its cave it will be on its way for a tune.
ID:	12344   Click image for larger version
Old 03-17-2012   #15
dsmghost
dsmghost's Avatar
Thanks, I was desperate. The guy I bought the motor from thought I was crazy when I was trying to load it.
Old 03-18-2012   #16
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Too funny I would of thought the same. Lol. When is that thing gonna be ready?
Old 03-18-2012   #17
dsmghost
dsmghost's Avatar
I'm doing my best, I'm hoping by summer. Still have a lot of saving to do.
Old 03-18-2012   #18
If you are just running a small 16g there is no reason for a FP manifold or SMIM. Save yourself some money and skip those for now. They are very easy to do later if you decide to go with a bigger turbo. Do you already have the small 16g?
Old 03-18-2012   #19
dsmghost
dsmghost's Avatar
Yeah I have the small 16g. I got the SMIM with the shell I bought. My stock exhaust manifold is cracked, and I dont want to buy a cheap ebay manifold or another crack proned stock manifold. The FP manifold is great quality and not too expensive.
Old 03-18-2012   #20
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Sell the smim, and buy an FP manifold. A SMIM will prob do more hurt than good with that small of a turbo. Depending on the SMIM (which is JMF if I'm not mistaken), you prob will still have money leftover for your build.
