Old 07-26-2012   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
No start, fuel good, no spark.
I have been searching and searching about this issue. For some odd reason I cannot get my car to start up. It turns and turns and turns. The fuel is good and pressure is fine. I am not getting spark to my spark plugs. The car is a 91 with a 91+ motor/wiring harness. I am not to sure if the ECU is a 91 or a 90. Everything is plugged in correctly. I was going to switch the 6 and 14 wires on the ECU but I do not think that is my problem since most people say it will just make you idle rough, not make a no start. The car had an alarm system. I looked over the interior harness and nothing looks out of the ordinary. My MAS is plugged in, I haven't checked for power to my CAS but am just waiting for a roommate to wake up to do that. Is there anything else I am over looking?
Thanks,
-Colin
Old 07-26-2012   #2
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: No start, fuel good, no spark.
Another thing to add, I looked up the ECU and it is a late 90s to early 92. So I am not going to switch the pins as of current.
-Colin
Old 07-26-2012   #3
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
I get power to my coil pack, and power transistor/ignition module but no spark when I crank it over.
-Colin
Old 07-26-2012   #4
Check the wire on the cam sensor, they can crack. A bad ground is also a possibility.
Old 07-26-2012   #5
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
got it running, the 66 and 63 wires from the ECU were loose and spliced together??!
-Colin
Old 07-28-2012   #6
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Nice work man
2006 WW IX RS 396/404 - SOLD
