Old 11-29-2012   #1
4seasons69
4seasons69's Avatar
Wideband o2 question
Okay so I have an older FJO wideband in my car. It won't read under 13.0:1. I was just going to try a new sensor but a new sensor is almost $300. So my question is this kind of sensor really worth it and that much better? Or should I just get a whole new wide band setup?
Old 11-29-2012   #2
Re: Wideband o2 question
New setup.
Old 11-29-2012   #3
mdost03
Sonic Champion!
Drives: VA STI
Probably just get a new setup. New AEM widebands are going for around $160 nowadays.
Old 11-29-2012   #4
wtf is an FJO? Some crap swifty got for cheap and tried to make work?
Old 11-29-2012   #5
4seasons69
4seasons69's Avatar
FJO is a brand lol. they seem to be a quality part from what I've found. the older one uses a different sensor that is expensive. I was just wondering if there were any benefits to running this type of sensor that would justify spending almost $300 on just the sensor
Old 11-29-2012   #6
I have a PLX M300 for sale.
Old 11-29-2012   #7
4seasons69
4seasons69's Avatar
How much? I'm not exactly in the market for a wideband just yet. I have to finish getting my engine together and back in first
Old 11-29-2012   #8
Just get a new one. PLX's are nice, that's what I ran in my Talon.
Old 11-29-2012   #9
4seasons69
4seasons69's Avatar
A new one it is. I kind of like the plx m300 or the ngk one since they are boxes like the fjo that way it will be easy to install without having to figure out how to mount a new gauge
Old 11-29-2012   #10
FJO was the most commonly used units until the cheaper Bosch sensor based wideband started coming out in the mid 2000s. They usually used an NTK sensor instead of the Bosch. The NTK sensor lasts much much longer, is more accurate, and doesn't die right away on leaded gas.
Old 11-29-2012   #11
4seasons69
4seasons69's Avatar
Is there a new and old style ntk sensor or something? I was looking into them and the new fjo the ngk wideband says it used an ntk sensor and the replacement sensors for that are like 150 and the replacement sensor for the older fjo I found was like 290
Old 11-29-2012   #12
You might be able to take one of the NTK sensor sensors, cut the connector off and then solder on the unique FJO connector. Post up some pics of your old sensor and any part #s on the sensor itself and I can compare to some of my NTK sensors.
Old 11-29-2012   #13
4seasons69
4seasons69's Avatar
Okay cool. The car is at my buddy's house but I will be over there this weekend working on it. I'll take some pictures and get the part numbers
Old 12-01-2012   #14
4seasons69
4seasons69's Avatar
Talking Re: Wideband o2 question
The only numbers I could see on the sensor was L1H1 and CS000. Here's a couple pics too
ID:	13146   Click image for larger version
ID:	13147   Click image for larger version
Old 12-03-2012   #15
It looks a lot like the NTK sensors I use, but the wire colors are different. Same connector.
I think the L1H1 NTK has been discontinued and replaced with the L2H2.
Old 12-03-2012   #16
Those ultra efficient Honda's used to come with a factory NTK sensor in the early 2000's, I don't know if they've gotten any cheaper since then.
Old 12-03-2012   #17
4seasons69
4seasons69's Avatar
Okay cool. So then would an L2H2 work in place of this sensor? And are they something that you stock?
I think Swifty did say it was the same sensor as one of those Hondas
Old 12-03-2012   #18
Those Honda one's haven't our 2005 o2 was $150+
Old 12-03-2012   #19
I don't stock that sensor. The L1H1 was used on some older Hondas.
http://www.oxygensensor.net/ntk_o2/24300.php
Old 12-03-2012   #20
4seasons69
4seasons69's Avatar
Ok cool. Thanks for the link!
