Old 11-27-2011   #1
91 Galant VR4 #597 Project redemption
This is my new Galant VR4 I picked up last week to get up and running as my new daily. It needs a turbo and the wiring fixed. Along with a hand full of other odds and ends. Tonight I fixed up the engine bay harness that was shortened by someone and when I did get the car home it would not start or run, but now it starts.
Its the green on the other side of the race car.
Its kind of weird to see them next to each other.
The turbo is bad, so I will be swapping that out starting tonight. And I am putting power steering back in the car, well the pump was never removed but the AWS was taken out, so I just need to cap the lines going to the back of the car.
Stock, not much to see here
I looked in the car today and found the factory limited edition key chain.
Some body messed with the engine bay harness a little to much.
They were doing it wrong.
I have a Eprom ECU I will use to tune the car. I am going to put the china evo 3 16g on the car and getting it driving around, then I will put some work into swapping on the mutt level 1 I put on the moon taxi, back in the day, and supporting mods to make a fun daily.
It also has the cyclone dual runner manifold on it now, I will do some thinking on if I can make it work like it should, that would help power under the curve a lot, something the moon taxi has none of, could be fun.
It also has a 4 bolt rear end and a 5 lug swap and a small FMIC with some OK piping. We will see how this comes together in the next week or so.
Old 11-28-2011   #2
twack
It was a auto get over it
twack's Avatar
Re: 91 Galant VR4 #597 Project redemption
seems like everyones getting a galant these days
Old 11-28-2011   #3
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
How'd you get it running? JUST curious.
ps: Where do you find all this motivation?
'04 Honda Ricer: stock
Old 11-28-2011   #4
If you look at the pic of the engine bay with the wirering all layer out I cut out every spot you see red shrink tube as they were soldered together there. A few wires for the coil and transistor pack broke as I was stripping the e tape off. So I figure there were a few connections that were not good.
And as for motivation, I am not sure.
Old 11-28-2011   #5
Drives: 98 iVTEC
so is the HG blown?
Old 11-28-2011   #6
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Yay for belize green! Looks like a decent pick-up for a daily. Glad to see it in good hands.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 11-28-2011   #7
lol. Nice work JDM.
It will be pimp having 2 GVR4s
Old 11-28-2011   #8
Wow nice work rescuing that thing!
Old 11-28-2011   #9
I do not know about the hg yet. I will get the turbo swap done then let it warm up all the way.
Old 11-28-2011   #10
Whoah sweet! Looks like a good car, if anyone can get this thing back roadworthy you are the man! Good luck and keep us updated!
Old 11-28-2011   #11
very nice
Old 01-01-2012   #12
I will up date later with more pics and the long list I went threw to make this thing a good DD. kind of funny when I towed it home we had snow, and my test drive tomorrow will be in fresh snow. But the hole time working on it, we had no snow.
Old 01-01-2012   #13
URV8SUX
URV8SUX's Avatar
Looks cool John are you going to put a trailer hitch on the DD to tow the race car to the track?
Old 01-02-2012   #14
Yes I should.
Old 01-02-2012   #15
123abc
123abc's Avatar
Drives: Loud cars
So the long block ended up being just fine then? No HG issues?
Old 01-02-2012   #16
I will fully warm up the car today and drive it around the block. I will know for sure then.
Old 01-02-2012   #17
So I drove it around a little tonight. The CAS stopped working after it was warmed up, so I swapped that out. There might be a lower end knock on #2 I will put a few more miles on it to see what else I will need to fix. And order some bearings I guess.
Old 01-28-2012   #18
updates?
Old 03-15-2012   #19
Time for a small update.
Long story short the motor was junk, rod knock and leaks all over, a lot of blow by shot rings and valve seals. The clutch slipped and just about everything bangs or rattles.
So it now has the backup motor, twin disk, and ems from the race car in it.
At wg pressure with a 16g we are at 210hp/220tq.
There will be some changes and a small list of things to make it a good DD.
I will run the 16g till it lets go then a bigger turbo and upgrade the fuel and IC setup.
Old 03-15-2012   #20
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Just like a Boss ! ha
