Old 03-16-2013   #1
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
LQ4 or L33
Lower comp with larger displacement, or higher comp/better heads and lighter weight. Which would you go with?
Both around the same price. On a budget
Car is 3700 lbs with 4.11's 3500 stall. Driving around for a year or two with only a cam/intake swap and future plans for boost.
LMK your thoughts
Old 03-16-2013   #2
Re: LQ4 or L33
depends on HP goal. The cast iron block is nice, but moves around just as much as the aluminum version. You can make a nice 408 CI out of the cast iron block and put hard block up to the bottom of the water pump holes and its a great base for 1000whp turbo setup. The smaller displacement aluminum blocks do well also, just make sure the engine machine work is done with the mains and both torque plates bolted on, and hard block as well.
Give MAP a call, they are working more and more with turbo LS stuff.
Old 03-16-2013   #3
golden763
Drives: 95talon tsi
Re: LQ4 or L33
Or get an lq9 they got the good 6.0 block and rotating assemblies but have way better flowing heads than the lq4. I'm pretty sure they were in escalades and such
Old 03-16-2013   #4
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: LQ4 or L33
No block fill or machine work. Guys are getting redonk power out of both with stock internals
The only difference between a LQ4 and a LQ9 is the pistons. Everything else is the same including block and heads
Old 03-16-2013   #5
93gtpeater
Drives: cbr 1000rr repsol
Re: LQ4 or L33
I say get the one with better heads. More flow more power.
Old 03-16-2013   #6
Re: LQ4 or L33
Yeah, I haven't heard of filling the block at street power levels. Get the 6.0 block, put the factory aluminum heads slightly ported, done.
I found out my 07 Tahoe came factory with pretty much the C5 Z06 heads. If it didn't weigh 5000+ pounds, it would be pretty quick.
Old 03-16-2013   #7
Re: LQ4 or L33
I have a LQ4 in my Denali XL and it is really strong, even stock with 325hp. 5,600lb curb weight and 1/4 mile in the very low 15's. Pretty impressive.
Old 03-16-2013   #8
1999Gst
Drives: 1999 Eclipse,
Re: LQ4 or L33
Lq4 there bullet proof.
Old 03-18-2013   #9
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: LQ4 or L33
Ended up finding a minty 16K mile L33 for a good price so I'm going to pick it up this week.
Like the idea of 100 less lbs hanging over the front.
Old 03-18-2013   #10
Re: LQ4 or L33
Nice choice! They are getting cheap enough that we are going to see them stuffed in more and more things.
Old 03-18-2013   #11
Re: LQ4 or L33
Less weight out front = easier wheelies!
Old 03-19-2013   #12
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: LQ4 or L33
I reckon Imma have to start a build thread
Old 03-19-2013   #13
Re: LQ4 or L33
Damn straight!
