Old 03-30-2013   #1
cliford_thefast_redcar
Drives: 95 gsx
no spark-no fuel
i was wondering what the problem with my car could be it died while driving i have have no spark and cant hear the fuel pump cycle when key is on the on position... hear it could be the cam angle sensor from a buddy that had the same problem with his evo... any suggestions?
cliford_thefast_redcar is offline   Reply With Quote
Old 03-30-2013   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: no spark-no fuel
Did you check all your fuses? That should be your first step.
Is the check engine light on?
On the 2g, crank signal fires the coil pack for spark, cam signal fires the injectors and gives power to the pump.
There is a bunch of different things it could be. Power transistor (black skinny square box by the coil pack), Cam sensor, Crank sensor, MFI relay (under the dash on the passenger side of the center console).
Easiest way to figure whats going on is with a scan tool to make sure the cam and crank sensor are giving the ECU a signal. Also could have a buddy try to start the car while you test for power at the fuel pump.
Originally Posted by shoutbox
Old 03-30-2013   #3
Drives: 95 gsx
i have checked the fuses and no the check engine light isnt on have a a blue point scan tool but i dont think it goes that far in depth
Old 03-30-2013   #4
Drives: 95 gsx
if any one could come help that would be great
Old 03-30-2013   #5
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
When you turn the key on does the check engine light come on fir a second then then go off?
If it doesn't you need an ecu.
Old 03-30-2013   #6
Drives: 95 gsx
it comes on for like six sec. then turns off
Old 03-30-2013   #7
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So ruled that out. Check you relay located under the radio behind the passenger kick panel. Replace with known good one.
It's either a gold box or 2 small black boxes that's are connected.
Gold one looks like this
Old 03-30-2013   #8
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
This
Could definetly be the MPFI relay
Old 03-30-2013   #9
Drives: 95 gsx
you have any extra ones of those and i ordered a crank sensor also just in case it is that
Old 03-30-2013   #10
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I have every part needed to diagnose or pinpoint a no start.
Old 03-30-2013   #11
Drives: 95 gsx
woud you maybe want to help me tomorrow at some point
Old 03-31-2013   #12
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I'm working all day today. I honestly have no free time to help. Works picking up and I have my own projects to deal with right now. The rest of the time is spent with the family.
Old 04-07-2013   #13
Drives: 95 gsx
car still has no spark i have replaced the cam sensor and the cranks sensor.. also put different transistor and different coils in vehicle.. any one have any other ideas or would be willing to come take a look at the car? car does have fuel can hear the relay click and disconnected the line and it sprays fuel out
Old 04-07-2013   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
What did you do to test for spark? Like how do you know it doesnt have spark, what tests did you do to diagnose that?
Have you done a compression test?
Did you replace the "transistor box" with the coil pack? Its the little black box next to the coil pack.
