Old 04-03-2013   #1
dsmghost
dsmghost's Avatar
Drives: 1gb Talon TSi AWD
Bad Prosport fuel pressure gauges
I thought I would share this info. A couple weeks ago I ordered a Prosport performance series electronic fuel pressure gauge kit. I installed the kit and the gauge reads 13 psi high, after testing the sending unit, I found the resistance was out of spec. It was 5 ohms, needs minimum 10 ohms. Contacted Prosport, had a new sender at my door a week later. With the new sender installed the gauge read 10 psi high, tested it at 6 ohms. It says right on the sender 10-180 ohms. After a few calls with Prosport I found out this is a known issue and they don't have any answers. He said if I can wait a while hopefully they will have an answer/solution in about ten days.
I ordered online through MAP, I know they have nothing to do with the problem. That's why I contacted Prosport directly. I'm wondering why Prosport is still selling these kits if they know they are defective. Hopefully nobody used a Prosport fuel pressure gauge to set their fuel pressure without verifying pressure with a mechanical gauge.
Old 04-03-2013   #2
Re: Bad Prosport fuel pressure gauges
Nice
Old 04-03-2013   #3
LingLing
AznKraut
LingLing's Avatar
Ouch.
I have never trusted Prosport stuff. I had one of their oil pressure gauges that wouldn't read correctly after a month of use. I'll pay a little extra for an Auto Meter any day of the week.
In a perfect world they'll ask if you want a replacement or your money back.
Old 04-03-2013   #4
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Well this is unsettling now that I wanted to buy all of my gauges. Lol
Old 04-03-2013   #5
LingLing
AznKraut
LingLing's Avatar
Don't get me wrong, I'm not saying all Prosport stuff is junk. I don't know if that's true. But for $40+ gauge I expect it to work properly for more than a month. Especially one as critical as oil pressure.
I'm interested to see how Prosport handles this.
Old 04-03-2013   #6
I'm selling a fuel PSI/voltage dual gauge....
The voltage can be hooked up anywhere, i had it at my fuel pump to check voltage at the pump since that is important for fuel delivery.
I also have boost, trans temp, oil psi.
Old 04-03-2013   #7
I also have boost, trans temp, oil psi/water temp dual gauge.
Old 04-03-2013   #8
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
something i learned about prosport gauges, and most cheap aftermarket guages in general. They're little more than dummy lights, to tell you whether you have pressure/temperature or not. Maybe you can count on it within a couple orders of magnitude :P
Style's automotive engineer
Old 04-04-2013   #9
99gsxjoel
Drives: 1999 GSX
I have a prosport electric boost gauge and don't have any issues with it yet. It's been 1 year since it was install and am interested in seeing if it reads the same as db's dyno in a month or so.
99gsxjoel is offline   Reply With Quote
Old 04-11-2013   #10
dsmghost
dsmghost's Avatar
Prosport called me yesterday to verify which gauge I had. He said his boss is in Taiwan searching for a new manufacturer wtf, all the bad senders say JPN on them for Japan. He said he will give me a call again soon. I'm just waiting to see what happens, I'll most likely end up getting my money back because this is stupid.
If you have any electronic prosport gauges test them, or verify they are correct using a mechanical gauge, I don't think it is just the fuel senders they have problems with.
Old 04-11-2013   #11
LingLing
AznKraut
LingLing's Avatar
Is it just me, or do you automatically think mediocre quality when you hear "Made in Taiwan"
Old 04-11-2013   #12
Fran05
Drives: DSM
Prosport is junk. Coolant temp one reads 20deg lower than it should in my friends car. All prosport is a bling bling OMG KEWL NEON BLUE LIGHTS OMG IT BEEPS OMFG
Old 04-11-2013   #13
LingLing
AznKraut
LingLing's Avatar
Prosports are good for the person on a tight budget. But, like most everything else that's inexpensive, there are drawbacks.
Old 04-12-2013   #14
I had prosport gauges in my 2g. They failed within a thousand miles (oil pressure and water temp). Decided to get real gauges in my new car, they aren't that much more money.
Old 04-13-2013   #15
LingLing
AznKraut
LingLing's Avatar
Did a quick Google search and there seems to only be about a $25-$30 difference between Poorsport and Auto Feeder. Well worth the health of built motor if you ask me.
Old 04-13-2013   #16
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
I bought an autometer oil pressure gauge, and a boost/vac gauge for like $25 used on here. Never had issues, this makes me happy that I never went with prosport.
mitsukid124 is offline   Reply With Quote
