Old 08-26-2014   #1
Capinoy123
Capinoy123's Avatar
Hesitation WOT
So This year my car does not want to run under WOT. Built 2.0 liter BC 280 cams, ECM Link V2. (I'll try to take a log of my WOT tonight on my way home from class.) Bosch 044 Fuel pump -8 fuel feed, -6 return, aeromotive fuel pressure regulator. 1650 blue maxx injectors. Magnus Intake manifold 3" Gm maf so on and so forth. Just trying to get ideas. I use to run 25 PSI all day long but it starts to hesitate as soon as it hits full boost or shortly after. So i thought ignition issues? So i turn the boost as low as it would go. 12 PSI and same thing still hesitates under WOT. I'm running about 11.0-12.0 A/F at WOT. Any suggestions would help thanks!
Old 08-26-2014   #2
Re: Hesitation WOT
Did you try new plugs? 12psi is pretty low to have spark blowout though.
Old 08-26-2014   #3
Capinoy123
Capinoy123's Avatar
Re: Hesitation WOT
Yup! First thing i tried. Still the same result! BPR7ES! I have a coil on plug setup too FYI.
Old 08-26-2014   #4
Re: Hesitation WOT
Fuel issue? old gas? filter?
Old 08-27-2014   #5
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: Hesitation WOT
Bad coil pack? Try running stock coil pack and plug wires. Fwiw 11 afr on e85 seems pretty rich. I wouldn't rule out that it is too rich as that will give you issues. Any knock?
Old 08-27-2014   #6
Re: Hesitation WOT
Post a log!
Old 08-27-2014   #7
Capinoy123
Capinoy123's Avatar
Re: Hesitation WOT
What is a good a/f ratio for e-85 at WOT? I will definitely try my stock coil pack and plugs this weekend hopefully! Also maybe get a WOT log! I will also look into my fuel system..
Old 08-28-2014   #8
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: Hesitation WOT
11.8-12.0 is safe IMO
