Old 09-21-2015   #1
mdost03
Sonic Champion!
Drives: VA STI
Fuel Pump Upgrade Question
So I'm going to be upgrading my fuel pump soon and would like some opinions on which to go with. I was initially just going to throw a 255 pump in, but now I'm seeing DW has their DW300 pump and Aeromotive has their 340 Stealth pump also. Right now, I would just be using it with gas and running around 20psi on the e16g turbo, but eventually want to run e85 in the future so I'd like a pump that can handle that as well. Anyone have experience with any of these new pumps? I'm wanting a drop-in pump instead of an in line setup so I'd like one of these I listed.
Thanks!
Old 09-21-2015   #2
Re: Fuel Pump Upgrade Question
modded 255
Old 09-21-2015   #3
My DW300 has been great, no issues logged over 55lb/min with it on E85.
Old 09-22-2015   #4
mdost03
Sonic Champion!
Drives: VA STI
Did it install just like a walbro pump?
Old 09-22-2015   #5
^Yep.
IIRC it might be physically smaller which is nice, not as loud either. Still have fuel left in it to turn up the boost. I think it's done 500-550whp on a dynojet on E85 before.
Old 09-22-2015   #6
mdost03
Sonic Champion!
Drives: VA STI
^Yep.
From what I've read, these pumps really like higher voltage so a BAP can probably up that a bit too on ethanol. I'm leaning towards trying out the DW300 I think. Thanks!
Old 09-22-2015   #7
Good thinking I could try a bap before I jump to a 450.
Old 09-22-2015   #8
I've always ran 255HP's.
Old 09-26-2015   #9
255 will handle all you'll ever throw at that 16g
Old 09-26-2015   #10
mdost03
Sonic Champion!
Drives: VA STI
I went with the DW300, wanted to try something new since I've had walbros wear out quickly in the past. Also a fuel lab fpr kit to go with it. I noticed I'm leaning out up top, stock pump, fpr, and evo injectors can't keep up.
Old 09-27-2015   #11
I hope it's just the pump not keeping up, I'm not 100% but I feel like 560s should be fine on pump.
Old 09-27-2015   #12
mdost03
Sonic Champion!
Drives: VA STI
Car has 167k miles on it, no idea if pump has ever been changed in the past. Will swap out and see if it fixes it once it comes.
Old 09-28-2015   #13
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
What are you driving now a days sir?
2006 WW IX RS 396/404 - SOLD
Old 09-29-2015   #14
mdost03
Sonic Champion!
Drives: VA STI
My daily is an 06 Eclipse and the talon has turned into the project car.
Old 09-28-2015   #15
Stock pump and stock wiring to fuel pump won't go very far. Upgrading those should give a lot more fuel.
Old 09-29-2015   #16
DW would be my choice. I had Whinebro failures on both my Evos.
Old 09-29-2015   #17
URV8SUX
URV8SUX's Avatar
I have a Jay Racing 044 pump for $100 if your interested!
Old 09-29-2015   #18
Nate, can you post that link up again that you linked to in the SB the other day.
Old 09-29-2015   #19
http://webpages.charter.net/hybrdthr...mp_web_app.htm
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 09-29-2015   #20
Hughes/Scheides, can we get this put in the good stuff section or stickied somewhere?
