Old 07-31-2004   #1
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
Rickey isn't able to post right now so I'm posting this for him.
"I hit a drop in the pavement going a little fast. then my car started to make a little rattle at the beginning of acceleration. This went on for like three days or so, then the rattle got louder. Now it does it whenever I'm on the gas. it sounds like there are rocks or something jumping around in there."
Any help would be appreciated.
Khadgar is offline   Reply With Quote
Old 08-01-2004   #2
john
Business as usual
john's Avatar
Well I would call rocks jumping around in there lifter tick assuming you are talking about small rocks.
97 Viper GTS
Old 08-01-2004   #3
Khadgar
No, he says it sounds like big rocks, and its below the VC somewhere, he said he pulled off the VC and everything on the head looks like its in palce, I was thinking a loose rocker untill he said that.
Old 08-01-2004   #4
Check to see if his timing is still correct. There is a possiblilty he jumped a tooth but thats hard to beleive. If the engine is very sluggish while trying to build and boost and your here knocking that might be the problem... other wise Im not sure.
Old 08-01-2004   #5
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
Maybe its a collapsed lifter.
tsiawdspeed is offline   Reply With Quote
Old 08-01-2004   #6
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
I kinda wonder if it's just a loose nut on a belt pulley...
Old 08-04-2004   #7
john
Business as usual
john's Avatar
My car has the same problem now after fixing my oil leaks. Sounds like CLICK CLlICK CLICK. Seems to be rpm and throttle based for me. Seems to come on around 2000 rpm at low throttle. My knock sensor goes running with it. I see up to 40 counts at times. Any ideas? My head was rebuilt 150 miles ago. Everything looks fine under the cover. Seems like it is coming from the intake cam side.
97 Viper GTS
