Old 08-12-2004   #1
NWburbDSM
NWburbDSM's Avatar
Send a message via AIM to NWburbDSM
i just bought a 1991 galant gsr w/ the non turbo 4g63 and its completely stock. the car wont start. it cranks but has no spark. i think it is that common ecu problem with the leaky capacitors, but i'm not sure. does any one have any more info on this info. any help would be great. i knew the car didnt run when i bought it, but for a car with a mint body and interior for $300, its hard to pass up.
SNO*DRIFT rally or bust!
NWburbDSM is offline   Reply With Quote
Old 08-12-2004   #2
1Fst14B
Send a message via AIM to 1Fst14B
possibly an ecu...do you have inj. pulse also?
its easy to take the ecu out and check for leakage....if its only spark it may be other things also...
adam
1Fst14B is offline   Reply With Quote
Old 08-13-2004   #3
NWburbDSM
NWburbDSM's Avatar
i have the ecu out. what should i look for?
Old 08-14-2004   #4
john
Business as usual
john's Avatar
Look for corrosion around the caps. If you are unsure, PM LightningGSX on here and he can take a look at it. He also is the one who replaces caps. He is doing my 90 ecu now.
97 Viper GTS
Old 08-14-2004   #5
NWburbDSM
NWburbDSM's Avatar
yeah it was leaking. i had a tech at my work look at it who has done a few of these done before. he said it was so bad that he couldn't fix it. so i just bought a remaned one from this place in penn state for $250 and has a one year warranty. not cheap but better than a new one!
Old 08-15-2004   #6
LightningGSX
Hellbound
What do you want for your old ECU?
-Nulli Secundus-
Old 08-18-2004   #7
NWburbDSM
NWburbDSM's Avatar
i have to send it back for the core, unless you want to give me over $100
