Old 08-18-2004   #1
My car whenever I psh the clutch in all the way makes a creeky groany noise and it feels kind of crunchy at the end. Like something is sticking.
I have a 2600 and it has about 25-30k on it (2 years). So Im wondering if anyone has had any similar issues and what to do about it before I tear it apart to see.
To my knowledge right now both the master and slave cylinder's are working fine. Engagement is a little low to the floor and thats because I know my pedal assembly is probably wearing out... I am going to work on that but I need to know if that is related or is a seperate issue with the clutch crunchiness.
TIA,
Peter
Old 08-18-2004   #2
joem
Drives: 1991 Talon awd auto
Sound like a tob to me.
joe
Old 08-20-2004   #3
Thats great. Anyone else have any ideas? What can go bad with it though? I mean do they fall apart after a while, was it install, or just wear?
Old 08-20-2004   #4
Enes
Enes's Avatar
go to elite and see if Mo still has the bad TOB from his car.. he ended up having to replace the clutch and the flywheel and PP ...
good luck..
-E
Old 08-20-2004   #5
How the heck does it take out the clutch, PP and flywheel? Other than the tranny grinding a little because of low engagement the clutch seems to be fine and it holds.
I hope its just the TOB. But thats why Im asking... what are some symtoms. Especially in Mo's car?
Old 08-20-2004   #6
Enes
Enes's Avatar
think what it does.. use logic... apply to the methodology and you will know why..
-E
Old 08-20-2004   #7
Jed
The RTFVfaq Guy
Jed's Avatar
Is the "creaky groany noise" coming from under the dash or outside the car?
Old 08-20-2004   #8
my reg 1g has mad a creeky noise sense the 2600 was installed(2 owners ago). It sounds like the clutch pedal assembly to me, but if its coming from the tranny then its not.
Old 08-20-2004   #9
Its coming from the tranny.
Enes- If I knew what was making the noise I wouldnt post... There has to be some reason its doing this. Either the shaft is really dry and the bearing is creeking when pushed all the way... or its something else.
Old 08-20-2004   #10
john
Business as usual
john's Avatar
The bearing could be out of grease, there could be some kind of shaft play, of it could be worn out. I swapped a new one on my tranny and the old one has some resistance in it. You can feel it catch a bit while lightly spinning it. I didn't have any problems with it though (noise, etc).
My friends 2g needs one. He is having a hard time getting into gears and it makes noise. Mitsu stocks the bearings. I believe they are ~$20.
97 Viper GTS
