Old 09-13-2004   #1
Enes
Enes's Avatar
Ok has anyone tried airplaine fuel in their dsms.. i got a source for the 110 octane for $1.90 / galon ... is it good to run in our cars? suposedly its low lead...?
-E
Old 09-13-2004   #2
Khadgar
Can't Actually Wrench
Send a message via AIM to Khadgar
On another note, anyone know a local source for Toulene?
Khadgar is offline   Reply With Quote
Old 09-13-2004   #3
-E
matt v has I believe.
khadgar-try home depot.
Old 09-13-2004   #4
Khadgar
Any bad things about toulene or is it fine to play with?
Old 09-13-2004   #5
Xylene works too, if you're a cheap ass.
Old 09-13-2004   #6
LightningGSX
Hellbound
Since TOLUENE is one of the top chemicals required for meth labs, you're likely to get flagged if you buy anything more than a small quantity or buy it more than once at the same store.Also the cops more than likely will fuck with you if you're pulled over and have it in your posession.Anyway, if you start with 92 octane, you get a octane increase of 1.5-2.2 points for every 10% of toluene you add.So a gallon of toluene and 9 gallons of gas will get you <94.2 octane, 2 gallons to 8 gallons gas will get you <96.4 octane.Not worth the trouble IMO.
-Nulli Secundus-
Old 09-13-2004   #7
Enes
Enes's Avatar
any info on the jet fuel tho.. its safe to run in the car?
anything i should be woried since it has lead in it like deposits on the head etc etc? can anything be done about that?
-e
Old 09-13-2004   #8
Don't use nitrous with AV gas.
Old 09-13-2004   #9
Enes
Enes's Avatar
u know me i'm anti juice... only once it will put me into 11's will i use juice...other than that.. no thanx..
but yeah.. so its fairly safe to run the AV fuel in dsms? any sidefects? i will get 10 galons and see how that goes.. espeically it being $1.90/galon thats very reasonable...
-E
Old 09-13-2004   #10
Go for it. Lead will kill your O2 sensor and plug your cat (if you still have one). Other than that it really isn't bad for anything.
Old 09-13-2004   #11
Enes
Enes's Avatar
what does it do to the 02 sensor.. anything i can do to clean it up?
oh, and i have a dog not a cat
-E
Old 09-13-2004   #12
LightningGSX
Hellbound
Lead contaminates the sensor.It won't kill it immediately, but seriously reduce the life.
-Nulli Secundus-
Old 09-13-2004   #13
Enes
Enes's Avatar
i will stop by the place today and see what it says on there.. but i heard its either 100LL or 110LL @ $1.90 /gal
my o2 sensor already has 85k miles on it and about 20 galons of 110leaded gas thru it..
i will take it out and see the condition of it maybe even get a new one..
-E
Old 09-13-2004   #14
illz
i wouldn't, here's why:
"The local airfield sells 100 octane low lead av gas for $2.61/gal.
Since 91 runs $2.40/gal. around here I have considered switching over.
Thanks."
"100ll does still contain LOTS of lead. I ran it with a 50/50 mix once.
It's not as much as the spark plugs you have to worry about as the valve guides. Avgas does not contain the top lube packages that mogas does.
It's safe to run when diluded with mogas or some sort of top lube, but running it straight wont help the valve guides any. Another side effect of avgas is that TEL is extremely corrosive, and will eat your cylinder walls right now when the motor is not running."
"Not only would I expect that "low lead" to kill your O2, but I also expect it to fowl your plugs. The industry joke about aviation "LL"
fuel is that it stands for lots of lead. It is lower then what they used to have, but it is a huge amount still as the engines for the most part were designed in the 30's and require it.
Anyone else run aviation fuel?
I know my buddies that fly with non-aviation based engines (ie modern combustion chambers) have to carry spare spark plugs when they are forced to fill up with 100LL."
Old 09-13-2004   #15
Jacek
Captain J-Sack
avgas and jet fuel are two different things. it still contains a good amount of TEL in it. My friend runs it in his classic v8 all the time.
Old 09-13-2004   #16
Yep, av gas still has way more lead in it than even leaded race gas. I wondered about it back when I was a pilot and I checked into it. It wasn't worth it.
3 gallons of toluene with 7 gallons of 92 would get you 98.4 octane. Not bad to go play with on the weekend and it is unleaded.
