Old 10-18-2004   #1
So I went to a local junkyard this morning and they have a N/A 2.0 Laser in there. I've seen so many different bits of information about about the N/A stuff. Can the N/A block & head be used in a turbo application? What about the tranny?
Thanks!
Old 10-18-2004   #2
Raptor
ConArtist
Raptor's Avatar
Engine yes if built for it. Tranny, I wouldn't.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 10-18-2004   #3
Thanks Mike! Are the N/A rods the same as the turbo rods? Is there any actual difference between the N/A head & block versus the turbo version? Possibly oil squirters?
Old 10-18-2004   #4
Raptor
ConArtist
Raptor's Avatar
Yep, no squirters and different pistons. The squirters being gone can be a good thing in some apps anyway.
651-488-7774
Old 10-22-2004   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
and just to add the non turbo heads have different cams
Originally Posted by shoutbox
Old 11-14-2004   #6
joem
Drives: 1991 Talon awd auto
The 1g head has no turbo oil boss for the feed.
joe
Old 12-03-2004   #7
Sean485
Guest
Tournaments Won: 6
Posts: n/a
joe
Sure it does, it just has a bolt with a crush washer blocking it off. As already mentioned cams aside they are exactly the same
As for the lower half of the engine the rods, crank, and block are the same. The pistons, clutch, flywheel, trans are different and the engine lacks oil squirters but they could be installed easily enough by a machine shop.
