Old 01-31-2005   #1
remy
Guest
Tournaments Won: 6
Posts: n/a
problem
When trying to tune today, at WOT, the car went boom and killed on me. The rpm guage doesn't work on the safc or the guage cluster. The car will crank but does not spark. The T-belt is fine also unless it skipped. Could this be caused by the SAFC connection that goes to the computer coming out? Would this cause it not to start? I don't have time to look at it now because I work.
Thanks
Old 01-31-2005   #2
Re: problem
Does the AFC have power at all? If not, the plug going in unclipped itself. Just open it up and plug it back in.
Old 01-31-2005   #3
Re: problem
Please state the car this is on, 1g or 2g. I would check the CAS too, if the problem isn't something really simple.
Old 01-31-2005   #4
remy
Guest
Tournaments Won: 6
Posts: n/a
Re: problem
it is a 2g gst and it seemed like the car was cutting in and out a littler bit. The rest of the SAFC has power. I reconnected one wire that needed to be fixed for the power, But I didn't have any time to check anymore.
Old 01-31-2005   #5
john
Business as usual
john's Avatar
Re: problem
Wires seemed fine. Nothing needed to be reconnected. Something could have happened to the rpm wire though... Appeared fine and the wire it was tapped off it was still together. Possibly the CAS or something...
97 Viper GTS
Old 01-31-2005   #6
LightningGSX
Hellbound
Re: problem
It doesn't sound like the AFC has anything do with it.Do you have a multimeter? Check the CAS and the transistor.
-Nulli Secundus-
Old 01-31-2005   #7
Re: problem
Crank walk eating the crank sensor?
Old 01-31-2005   #8
Re: problem
The crank tollerance was .009 when mike checked less than a month ago so it was walking but not walked yet. Bartons went to .030 and I thought it ate sensors at .020?
Old 01-31-2005   #9
john
Business as usual
john's Avatar
Re: problem
SAFC works fine except does not register rpm either. Code p203 popped earlier (#3 injector). There are no check engine codes present now. The prior one was cleared and did not come back on. Something happened, the gauges turned off and the car stalled while moving. Has oil, cranks fine. Timing belt is also on there. Haven't checked to see if it jumped though. The car still had an exhaust tone though while slowing down??? Haven't had a chance to check if out yet. Happened before work.
97 Viper GTS
Old 01-31-2005   #10
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: problem
Sounds similar to what mine did when my ECU went out. I didn't get any sensor response on the afc or datalogger.
11.35 @ 120mph
Old 01-31-2005   #11
Re: problem
ecu. Did you do a proper install with the afc, or a blue-snappy-T install? If one thing or the other crossed, buh-bye!
Check the ecu for blackness.
Old 01-31-2005   #12
john
Business as usual
john's Avatar
Re: problem
No, I used the red tap splices. Has worked on the 3 other cars without a problem. I would guess that the ecu is fine but will probly be pulled in a couple of days for dsmlink if the car can get running. The car may have been wheel hopping a bit and knocked a connector loose. May check over tonight.
97 Viper GTS
Old 01-31-2005   #13
john
Business as usual
john's Avatar
Re: problem
The car gets fuel but no spark. The ecu is out of the question so I need to figure out how to test the cas on a 95.
97 Viper GTS
Old 02-01-2005   #14
john
Business as usual
john's Avatar
Re: problem
Could I just wire in a 1g cas? It seems easier than pulling the intake cam and checking it that way.
97 Viper GTS
Old 02-01-2005   #15
LightningGSX
Hellbound
Re: problem
I believe you can, but the pulses will be inverted.It would let you know if thats the problem though.I'm about 95% sure its your CAS or the CAS's wiring.The easiest thing to do would be to take a multimeter, set it to AC, put the positive lead on the RPM wire of the AFC(or the CAS wire), ground the negative lead and check for voltage during cranking.
-Nulli Secundus-
Old 02-01-2005   #16
john
Business as usual
john's Avatar
Re: problem
No voltage would mean that the CAS is not functioning right? All the testing is doing is checking for any voltage correct. Then I can use one of my gay voltage testers instead of getting a new battery for the miltimeter.
97 Viper GTS
Old 02-01-2005   #17
Re: problem
We will try it after school today, Thanks
Old 02-01-2005   #18
LightningGSX
Hellbound
Re: problem
You're checking for AC voltage though, so unless your gay voltage testers read AC, they won't work.
Yeah no voltage would mean the sensor is not functioning
-Nulli Secundus-
Old 02-01-2005   #19
john
Business as usual
john's Avatar
Re: problem
Ok, I just got back from checking it. I couldn't read anything off the SAFC wire or the ECU plug. I then went under the hood, popped the connector and checked the wires. With the multimeter grounded on the battery, there was no sign of any voltage on any of the three pins. So it looks like the CAS is shot. Hopefully I can find the one I threw aside when throwing a 2g head on a 1g... Looks like it may be time to swap the t-belt, HG and get some ARPs. Fucking 2gs...
97 Viper GTS
Old 02-01-2005   #20
john
Business as usual
john's Avatar
Re: problem
BTW, the multimeter setting it was tested on was AC 750 I believe.
97 Viper GTS
