Old 12-17-2003   #1
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Had my brother 92tsiawd84 install some neon lights in my car (under the seats). he hooked them up off of the lighter power and ground. Now, two weeks later the parking lights will not turn off. They will just stay on no matter which possition the switch is in. He disconnected the neons thinking that may be the problem but it didn't help it at all. Could it be the switch on the steering wheel? Maybe the extra current from the neons blew the switch. Could it be stuck in the on possition?
7/25/09
Old 12-17-2003   #2
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Sounds like either the switch has gone bad or you have a bad wire somewhere in the switch wiring. Try disconnecting the wiring for the headlight switch. If the lights stay on, check the wiring from the plug down to the power source. If they turn off, then your switch (or the wiring up from the plug to the switch) is bad.
Old 12-17-2003   #3
john
Business as usual
john's Avatar
Thanks for the info. I will check that tomorrow.
97 Viper GTS
Old 12-17-2003   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
I know it sounds like a basic answer, but it's the easiest way to troubleshoot it. Just remember the motto of troubleshooters "Eliminate the simple stuff first."
Good Luck. If you need some help with it (tracing wires and such) I can bring my mutlimeter up there and take a look at it. As long as you have a garage or something to do it in.
Old 12-18-2003   #5
john
Business as usual
john's Avatar
Yeah I have a garage and a multimeter. I am just too stupid to use it and cannot find the manual. I will have to settle for a circut tester I have laying around somewhere.
97 Viper GTS
Old 12-18-2003   #6
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Look for a wire shorted to ground. In most foreign vehicles(including DSM's) the parking light circuit is a negative trigger(wire rests at voltage and when put to ground triggers the circuit it is connected to) and such a short would force the lights on all the time. The negative trigger wires are blue with a white stripe or gray at the steering column(watch for plugs at the column wires like to change colors there). There is also one positive trigger wire(rests with a lack of voltage and goes positive to trigger the function) and that is green with a white stripe at a harness above the hood release(big old harness that runs to your instrument cluster). I believe these are the wires and their right location.
I would be willing to help if needed, but it should be pretty easy to find.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 12-18-2003   #7
Just curious? Does the car run ok still? Is there any other dash lights on the battery warning ect?
If any of that is happening check the 80A fuse for the alternator under the hood. Also make sure the all the relays are working. If the alternator fuse is blown it will cause all kinds of weird problems like, the lights staying on, dash lights coming on for no reason, power windows not working ect. It seems like a short or even a ECU problem.
If thats not blown it could be a lot of things. I would suspect a fuse or something since you put in them neons or whatever.
Old 12-18-2003   #8
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
If you find that it is a bad switch let me know. I have an extra 1G turnsignal/headlight/wiper switch you can have.
Old 12-19-2003   #9
john
Business as usual
john's Avatar
Thanks for all the ideas. I will probly start looking into it on saturday.
There is no dash warning light on. The gauges are still lit up, and parking lights remain on when the car is turned off. It the door opens you also hear the warning chime. I was thinking it may be a relay or something. To turn the lights off, I have to pull the fuse under the hood. Thanks
97 Viper GTS
Old 12-19-2003   #10
Definetly check the alternator fuse, thats the same thing my car was doing. To get the lights to turn off I had to pull the fuse.
CRAIG
