Old 06-02-2005   #1
A/C conversion..
I want to convert my a/c to r134a, from the r12. My a/c is still in working condition, and all installed, it just doesn't have that cold air. I am LEAVING the a/c in the car. 10hp is not important enough to me. So, where can I get the fittings for the a/c high and low pressure nozzles? Are they the same size, or is one bigger?
-A. Swift
Old 06-02-2005   #2
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Re: A/C conversion..
We still have some R12, R12 is better than R134A in the DSM system. but if you want to switch, you should take off the compressor and dump out the oil and refill with R134A oil replace the o-rings ,you can get the fittings from NAPA.
Take her to the limit!
Old 06-02-2005   #3
I had switched 2 of my DSM's to R134A, it definately didn't cool as good as R12. R134A doesn't cool as well as R12 and the DSM system doesn't have much extra capacity. When it was like 100* I would get 70* blowing out, so the inside of the car was still 85*+ with R134A. I said screw it and took it out.
Old 06-02-2005   #4
xluciusx
Send a message via ICQ to xluciusx Send a message via AIM to xluciusx Send a message via MSN to xluciusx Send a message via Yahoo to xluciusx
its kinda sad how after the ac is removed there is all that empty space back behind the engine with really nothing to go there...
xluciusx is offline   Reply With Quote
Old 06-02-2005   #5
More turbos. And NOS.
Old 06-02-2005   #6
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Buschur makes a kit that allows you to move your alternator back there so you can mount a T88 wherever you want
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 06-02-2005   #7
xluciusx
LOL T88...Yeah I definitely need one of those...maybe I'll turn my engine around and use that extra room for 2 of them
Old 06-02-2005   #8
well, we still have r12, but even at my cost for 12, 2 pounds is 50 bucks! r134 is 20..
-A. Swift
Old 06-02-2005   #9
My car was converted from R12 to a newer freon called FREEZE 12. It's even newer then R134. All the kit included was fittings to go over the old ones. No o-rings or oil changes neccessary. It was actually done by my shop on base in Yuma. All in all it cost me around 60 bucks for them to install the fittings, drain out the R12, and pu in the Freeze 12. It cools awesome too. So just another option for you to look at!
Old 06-03-2005   #10
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
Since Freeze-12 is 80% R-134a and 20% R-142b, the usual question would be "Why not just convert to R-134a?" but with the price of R-134a these days.....it is not much more money just to stay with good old R-12.
Also, Freeze-12 won't circulate mineral oil very well and that will affect the longevity of your new compressor.
Old 06-12-2005   #11
Man I guess I'm slow or something, but I don't really understand what you were saying in that first paragraph about the "usual question". I'm assuming you are just saying you are against using freeze 12. I really don't know anything about the stuff, or much about A/C in general, except for that my freeze 12 cools damn good, easily comparible to how well my R-12 worked, and is real cheap. So it works good for me! I'm just throwing out another option for him. I'm no AC expert. Freeze 12 seems to be working great for me. I have no idea if it's hurting my compressor. If the stuff is really bad freon, then sorry. But it sure is working good for me!
And as for your idle, here is the link on setting your idle
http://www.vfaq.com/mods/BISS-1G.html
I personally ended up just blocking off the ISC and FIAV with one of QPR's block-off plates.
Old 06-02-2005   #12
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Damn pussies and their A/C! Just get rid of it. True A/C is 80mph down the highway with the windows open and the sunroof up~!
Originally Posted by shoutbox
Old 06-02-2005   #13
StealthGST
StealthGST's Avatar
Send a message via AIM to StealthGST Send a message via MSN to StealthGST
Try that in traffic... Icky Sticky
1997 Converted 1995 Mitsubishi Eclipse GS-T w/ 6 bolt
StealthGST is offline   Reply With Quote
Old 06-02-2005   #14
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I dont live in a city where the traffic stops every 3 seconds.
Old 06-02-2005   #15
Yeah, no a/c def. sucks in traffic. I feel better knowing I'm not a pussy... Because I don't have a/c. Yep.
Old 06-02-2005   #16
I havent had it for 3 years... it died the year after I bought the damn car. haha. I plan on getting a recharge of R12 just because I know someone that can do it fairly cheap.
The audi we bought last fall, which had really nice cold AC decided it didnt want to have AC anymore and now it doesnt work. Damn cars.
Old 06-07-2005   #17
Well, since napa send me a defective shrader valve, there was a leak. So, the system has been cycled 3 times..r134 converted. It's colder then shit now, but There is another issue, that I hear is rather common? The rpms are rather low.quite low. The car wants to stall out on me when the clutch is depressed, and once it did. I adjusted by the idle screw, but when the ac is off, then the idle is high, and it does that revving thing. What can I do to fix this..I know there's that motor thing..the idler control module?? Anyway, Will a new one fix this? I have it set back to the way it was, and I am not using a/c unless I am on the highway, but dang..it's hot out these days!!
-A. Swift
Old 06-12-2005   #18
...anyone?
-A. Swift
Old 06-12-2005   #19
Welcome to DSM's. Make sure your ISC motor is centered, you do that by grounding certain pins, check the VFAQ for specifics.
Old 06-12-2005   #20
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
So I am totally not trying to take over this thread, and I would start a new one but it kinda relates... I still have my A/C in my 92 talon but it sucks like doesn't seem to blow at all (kinda the same way with the heat(i assume the fan is bad)) but just out of curiosity how hard IS it to remove A/C? and does it really take up 10 hp to run that little pump?
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
