Old 08-18-2005   #1
blageo23
AWD4G64
blageo23's Avatar
O2 Voltage
I hooked up my datalogger to my girlfriends car cuz the has a check engine code. It has something to do with the O2 sensors. So I looked at them in the logger and just at idle one of the O2 voltage was at like .2 and like -3%-5%. What do the percents mean? Also could that O2 be bad? Thats what im thinking.
Thanks,
Mike
Old 08-18-2005   #2
rick shindley
Guest
Tournaments Won: 6
Posts: n/a
Re: O2 Voltage
The O2 sensor liklely has a heater built-in so it can get up to operating temp (>650F) in a hurry. The heaters often burn out on old O2 sensors, but the sensor still can work if the exhaust can make it hot enough. That's usually no problem when the engine is operating above idle speed.
At idle the exhaust temps are cooler so, depending how far the O2 sensor is from the heat source, the O2 sensor may cool off enough at idle to not work properly.
If the O2 sensor voltage comes up to > 0.7V when you rev the engine a little then its heater is probably bad and the sensor will have to be replaced (unless you don't mind the check engine light on).
I tuned a 2G one spring day and its O2 stopped working each time I let the engine idle! I checked and its heater was bruned out.
Rick
Old 08-19-2005   #3
blageo23
AWD4G64
blageo23's Avatar
Re: O2 Voltage
Thanks! Maybe some more info would be good too. Just in case there might be somehting else. its a 1998 BMW 323IS, 95000 miles, 2.5 straight 6, The O2 i mentioned was the first one. The secound O2 comes up .6-.96 and like 60%. In what Ive heard is the "normal" range. Again what does the % mean? Thanks for the info Rick!
