Old 08-20-2005   #1
Timing Issue
1992 Talon Tsi AWD 5 speed 6 bolt
I just did timing belt, turbo replacement, headgasket. Car idles horribly and eventually dies. We were all set to check the timing, with the thing grounded that needs to be. With the timing light hooked to Cylinder 1, we can't see the timing marks on the crank pulley. I am 100% positive the timing marks were perfectly aligned (after many sets of rotations) when I was finished with the belt. We are getting spark, and fuel. Is the timing just really off somehow? Thanks, and hopefully I can make it to the cookout tomorrow!
Old 08-20-2005   #2
Re: Timing Issue
well we looked at the pully, the notch is hard to see
i guess we need some whiteout
Old 08-20-2005   #3
Re: Timing Issue
Looks Like Im a Moron. I'm guessing I didn't start my 1s timing belt off to a good start by NOT setting the engine to TDC. wow. if thats the case I hope my head is ok.
Old 08-20-2005   #4
blageo23
AWD4G64
blageo23's Avatar
Re: Timing Issue
FYI: I checked my 7bolt and one turn of the crank make the piston go from TDC to bottom back to TDC. So Im thinking its fine. I just thought maybe The pully you have is from a 90 or something. maybe its different or something.
Old 08-21-2005   #5
Re: Timing Issue
You didn't put the spacer plate on the crank pulley backwards, did you? The one that has the notch in it to align the timing. You will be about 2 teeth off if you put that on backwards.
Old 08-21-2005   #6
blageo23
AWD4G64
blageo23's Avatar
Re: Timing Issue
That plate has one notch in it and the crank pully only has one notch in it. No room for error there...
Old 08-21-2005   #7
Re: Timing Issue
You have all your vacuum lines hooked up? PCV valve hose on the back left side of the valve cover?
Old 08-21-2005   #8
Re: Timing Issue
Bzzzzt!!! Wrong answer! The plate can be put on backwards (like I said the first time). If the plate is put on backwards the timing will be about 2 teeth off. Now put your hat on and go sit in the corner!
Old 08-21-2005   #9
blageo23
AWD4G64
blageo23's Avatar
Re: Timing Issue
o i thinki i get it, it only goes on one way BUT you can take the plate and turn it the other way so the inside is out and the outside is in. Is that what you mean?
Old 08-22-2005   #10
Re: Timing Issue
Yes, it is very easy to do and it will go together fine either way.
Old 08-22-2005   #11
blageo23
AWD4G64
blageo23's Avatar
Re: Timing Issue
Yup thats what it was.
Old 08-22-2005   #12
Re: Timing Issue
It's all fixed! It was just the little plate inbetween the balance shaft and timing belts. Thanks everyone! Timing belt is super easy tho! More people should do it. Definately helps to have another person too!
