Old 09-11-2005   #1
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
Don't know what happened
Last thursday i was driving out to burnsville to look at some furniture with a couple buddies of mine. I was going up an on-ramp after driving about 1/2 an hour when my car wouildn't let me shift into any gear at all. I usually downshift and for some reason it wouldn't let me put it into 3rd. I sat at the light for about 10 seconds trying to get it into 1st gear. Finally i pressed the clutch in one more time and it let me put it into gear. Lately is has been hard for me to put it into 3rd especially when i'm accelerating fast. When i'm not accelerating fast the car seems to shift ok, but I just feel like something isn't right. Off my shifting problems, my cars idle whenever I start it the idle is about 2100rpms until it gets warmed up,then it goes back down to 700rpms. Is that normal for a 2g 6bolt swap?
BKs50trimGST is offline   Reply With Quote
Old 09-11-2005   #2
armthelaser
armthelaser's Avatar
Re: Don't know what happened
My car was doing something like that so I replaced the clutch master cylinder because it was leaking a little. It sounds like the same problem I had and replacing it fixed it.
armthelaser is offline   Reply With Quote
Old 09-11-2005   #3
BKs50trimGST
Post whore
When i rebuilt the engine I also replaced the clutch master cylinder, I remember when i first brought back the car from Rick Shindleys house everything felt perfect (clutch/transmission) wise, but now the car isn't shifting like it used to, not smooth and easy, I just think maybe the tranny is going.
Old 09-11-2005   #4
MATCHBX
Any 2 card caller.
MATCHBX's Avatar
Pinball Smash Up Champion!
Might be air in the clutch lines. Bleed them and see if that makes it any better. Try the easy stuff first before you blame something expensive just to find it was a cheap and easy fix.
