Old 09-18-2005   #1
Little Bit of Everything.
Well Today was a Fun day. Went to Moroso for the First time. Wasn't able to race cause I wasn't running slicks but still fun none the less watched some cars run 4.9@150mph in the 1/8th mile and then hit up the GO-Kart Track at Moroso.
The rest of this is all Fiction:
Anyways to start on the way up there I was stopped at a Light and a Modified Porsche 928 Flew past me trying to make a yellow. Had a loud exhaust and really had some get up and go as it he canned it through the light. Luckly right as he went through my light turned green, I start to catch up to him "slowly" as to not scare him off, he sees me coming and I get to about 2 lengths behind him when he punch's it. I happened to be in a 3rd gear at probably 6K RPMS as I was already trying to slowly catch up. And here is a video I found a long time ago of someone else who must have had the same type of race but this would give you and idea.
http://www.scottbarton.net/Brian/Ecl...Porsche928.wmv
Logs showed: (peak Power) 22psi@92oct Creaping to 25psi by 9K
Knock:0.0
Timing:14.2 deg
InjDuty:90.5%
A/F Ratio:14.47:1
RPM: 8701 rpm
Front 02: .94V
CoolTmp: 210F
IntTemp: 85F
AirFlowlb:56.8 lb/min
AirFlow: 429.1 g/s
Airflow Per Rev: 2.96 g/Rev
Now Onto A Tech Question:
How do I get my DSMLINK to give me the Fuel trims up to 9K instead of 8K?
from 8-9K my rpms go up and down the entire time while climbing in rpms looks like this:
8500,8300, 8650,8210, 8700,8540 rpms. I don't get it. The Airflow keeps climbing but the rpms are speratic.
Back to the excitement:
On the way home from Moroso a WS6 with Skinny's and Slicks and a Cage pulls up to me on the highway. (wasn't ready with the camcorder otherwise I would have filmed it) Anways He Revs up on me, and I downshift into 3rd at like a 45mph roll) I was really in low rpms so I punched it as I new it would take a while for the turbo to spool, and I started to pull a head slowly put about 1 length on him(on like 7psi 4400rpms slowly going up to 10psi by 5200rpms) when he hit his Spray. He was pulling like a bad out of hell, got to about 2 lengths in front of me when my turbo finally went into full spool, and I held him at 2 lenths all the way through 4th. When he shut it down. We gave each other the thumbs up. I wish I'd asked him what he was running in the 1/4 that night that way I knew where my car would have been at. But Jenny and my Brothers wife were in the concord behind us and said it was an awesome race/extremely close once we got moving.
Old 09-18-2005   #2
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: Little Bit of Everything.
Find a dyno! You need some new numbers for your sig.
As for the RPM deal, I don't know.
Old 09-18-2005   #3
I definetely do need to find a dyno. The runs great up to 8K (which is where it's previously tuned to) but after that it pulls somewhat hard till 8500 but after that It feels like there's no torque/power even though the airflow keeps going up.
