Old 12-07-2005   #1
Megasquirt Vs. DSMlink
so which way do you all think that should i go, DSMlink or Megasquirt?
I have been reading up on both like crazy, with link there is tons of help available with the amazing number of people using link and what not. with megasquirt there aren't so many people but it is a complete standalone system. granted i don't need this right away but i only want to do things once and the right way too. Megasquirt is only $250. just wanted some opinions.
thx
Old 12-07-2005   #2
Re: Megasquirt Vs. DSMlink
If I had the option I'd give Megasquirt a shot. But from reading up on it, MS seems to require some hacking of the timing components before it'll read the signals from the crank and cam angle sensors correctly.
Old 12-07-2005   #3
I would do DSMLink. The stock knock sensing/noise filtering is second to none. I have never used a Megasquirt, it seems like most of the people who use them do all their tuning themselves anyways, and I usually only hear of them on cars that don't have any other good tuning options available for them, or a real full featured standalone system costs more than the car is worth.
Old 12-07-2005   #4
Why is this a versus thread.
For a dsm....
DSMlink > Megasquirt. Like Shane said, the Megasquirt is only used on applications that don't have a piggyback or standalone suited for that type of vehicle.
Old 12-07-2005   #5
dsm10sec
dsm10sec's Avatar
Send a message via AIM to dsm10sec
Where has LightningGSX been? I'm sure he has plenty of insight to this.
dsm10sec is offline   Reply With Quote
Old 12-07-2005   #6
Use the "KISS" method. "Keep It Simple Stupid". DSMLink works greatly for 95% of the DSM's out there. Biggest bang for the buck.
Old 12-07-2005   #7
I have only ever heard of 1 DSM successfully running Megasquirt and that's a 2G in the Omaha area, if that says anything.
Old 12-08-2005   #8
i have been reading on this a little and megasquirt seems great, but i would prefer dsmlink as for the obvious reasons. if some of you that know about the features of dsmlink could look a little into megasquirt and see what u think. i just want the one that controls the most stuff that i would mess with, there is no point having a program that changes shit that will never get touched. oh, there are quite a few running megasquirt, most just the fuel control side of it, the rest with the fuel and spark control.
Old 12-08-2005   #9
If you want the most control, go AEM EMS. Other wise, DSMLink will be fine.
Old 12-08-2005   #10
dsm10sec
dsm10sec's Avatar
Wasn't LightningGSX running MS? I swore I read something he wrote on tuners saying he does or did.
Old 12-08-2005   #11
Jepherz
Send a message via AIM to Jepherz
Actually, I believe the first guy to run MS in a DSM was a 1g. His name is prez on the boards, so if you search DSMToonerz you should find his posts. H was from Omaha I believe, but when I had met him, he had just moved to Des Moines. This was around 3 months ago???
1991 GVR4 1881/2000
1993 Eclipse
Jepherz is offline   Reply With Quote
Old 12-10-2005   #12
i bought and assembled MS2 with the v. 3.x board and i haven't installed it on my quest because converting to MPI is more money than i care to spend on that engine at this specific time. maybe later. but in the meantime, i'd like to find a good candidate for my MS. maybe the lawnmower. how cool would a turbo'd 50 hp push mower be?
edit: oh yeah, the main reason i replied was about spark control - MS2 has either hall sensor or VR pickup for timing. i was planning on using an MSD flying magnet wheel on the crank pulley. and origionally also a 6AL with a 2 step box, but i found that you can install a high current circuit to drive a coil directly from MS2. and i figured there's probably some software that allows me to have a 2 step anyway.
that may not happen on that car now.
Old 12-10-2005   #13
Outlaw1
Resident Redneck
Outlaw1's Avatar
The majority of the people out there don't need aftermarket ECU's because they don't have any clue how to tune. If an inexperienced person feels the need to tune his/her own car, just be sure you're prepared to swap a blown head gasket or build a new engine. I'm not saying anyone is experienced or not experience, I'm just pointing out the obvious. I'd say most people don't understand how an S-AFC affects their tune.
As far as DSMLink vs. Megasquirt goes, DSMLink is ready to work right out of the box. It looks very user friendly. It's just a matter of tweaking fueling/timing tables for your specific needs. MegaSquirt is closer to an old school DFI. It was not built vehicle specific. You can get a ballpark tune, but it's not like starting with a bone stock Mitsu image.
Depending on how much power you want to make, an EPROM ECU with a custom chip may be the best and cheapest alternative for you. In the end, whether you're using an SEFI8LO, DFI, MegaSquirt, DSMLink or stock ECU w/S-AFC, if you understand how to manipulate the fueling/timing maps to get what you want, it doesn't matter how you get there.
Ask yourself these questions. What is my target A/F ratio? What is my target total timing? If you can't answer those questions, it's best to let someone like Shane tune it for you.
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 12-10-2005   #14
thx for the advice all, i have decided dsmlink, i do appreciate all the help. now i just need some $$$. (u guys rock)
Old 12-21-2005   #15
Onefast99gsx
I use dsmlink and love it. The support forum is second to none also.
Old 12-26-2005   #16
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I've always loved the idea of megasquirt, but like its been mentioned... you can do it much more simply by just getting DSMlink. I'm sure sometime in your life you'll come across a car that will need megasquirt because there will be no other options.
Old 01-02-2006   #17
Here is a video of Megasquirt in action on a DSM. http://www.1320video.com/vids/12.28RedRumDyno.wmv
Old 01-03-2006   #18
CarPsyco84
CarPsyco84's Avatar
AHAHAHAHAHHA!!!! shane you shoulda been tuning that thing!!
-When in doubt, Moar RPM.
Old 01-03-2006   #19
woot, drive 'em in, push 'em out.
Old 01-03-2006   #20
I have no idea why it takes 35psi to make only 450whp on a turbo that big, and then somehow manage to blow up the motor. Even weak 7-bolts can handle over 500whp and back when I had my 7-bolt 2.0l and a little 54-trim stage 2 turbo, it made 450whp at 25psi.
