Closed Thread
Old 02-07-2006   #1
96 Gsx Awd
96 Gsx Awd's Avatar
Send a message via AIM to 96 Gsx Awd
How did this hole get here??
i have done some research but still dont know as why a rod shot through my block?? any ideas?? i wasent even going too fast about 95
96 Gsx Awd is offline
Old 02-07-2006   #2
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: How did this hole get here??
Did you have your cruise on?
This does just happen in DSMs. Ask Rabe.
Shotgun! is offline
Old 02-07-2006   #3
Cruise has taken 2 out for me. (dsm's).
niterydr is offline
Old 02-07-2006   #4
I remember seeing that once, right after he tried keeping up with me running 28 pounds of boost on pump gas. Doh.
Goat Blower is offline
Old 02-08-2006   #5
Shotgun!
Totenritt
Shotgun!'s Avatar
Cruise destroys DSMs
Shotgun! is offline
Old 02-08-2006   #6
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
I use my cruise, and have used it for over eight years on the same car same engine, but I do have big rods sitting under 2G pistons :-) 1990 stock rods anyway.
Take her to the limit!
unreal808 is offline
Old 02-08-2006   #7
Shotgun!
Totenritt
Shotgun!'s Avatar
Neat. You better be knocking on wood right now. Infact, get a wood dash-inlay. You will need that.
Shotgun! is offline
Old 02-08-2006   #8
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
wait... can someone explain to me why cruise takes them out?
s1ngletracker is offline
Old 02-08-2006   #9
it actually turns into a deisel and the computer adds or subtracts fuel depending on load, it does nothing to the throttle. maybe.
FattyBoomBatty is offline
Old 02-08-2006   #10
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Yeah, cruise sucks!
-Colin
cudvig is offline
Old 02-08-2006   #11
Wizard
Actually the only thing it controls is the throttle. Hence the box that is attached to the throttle cables known as the cruise unit. The only way I could see cruise causing engine problems is by pushing in the clutch and the engine not releasing the cruise hold. This is not the cruise control's fault necc. There is a switch on your clutch pedal that disengages the cruise. Also, if your motor can't handle a second of rev-limit or high rpms....it was probably on it's way out anyways.
Wiz
Wizard is offline
Old 02-08-2006   #12
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Wiz
Holy cow this guy is wayyyyy smart!
Way to be a newb to the board.
-Colin
cudvig is offline
Old 02-08-2006   #13
Inside joke. Its just coincidence that so many have went under low load/cruise conditions.
Both of mine were oiling related (cruise=music=loud=not paying attention to motor).
niterydr is offline
Old 02-08-2006   #14
x-pride
x-pride's Avatar
You have a radio in your car!
x-pride is offline
Old 02-08-2006   #15
I have a full audio system and will have A/C before it runs.
niterydr is offline
Old 02-13-2006   #16
96 Gsx Awd
96 Gsx Awd's Avatar
no i did not have my cruise on
Old 02-14-2006   #17
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
damn, I'm not gonna be using my cruise anymore. I have enough problems as it is.
1slowdsm is offline
Old 02-15-2006   #18
TurboDomestics
TurboDomestics's Avatar
I have no cruise or radio!
4G63 0, Charlie 3
TurboDomestics is offline
Old 02-16-2006   #19
I have no cruise or airbags. I was feeling horny one night so i decided to molest my steering wheel. Now i have a hole in the center of my steering wheel and my cruise is not hooked up and i have no airbag. DAMN THESE HORMONES!!!!
tpunx99GSX is offline
Closed Thread
