Go Back   MitsuStyle > Hosted Support Forums > Brookdale Mitsubishi
Old 03-19-2006   #1
CV Shafts
Hey Chris! Can you look up two CV shafts and see if they are the same? I assume they'd have the same part numbers if they are the same.
Could you please look of a Front Passanger CV shaft for a 1991 or 1992 Galant VR4
Could look up the Front Passanger CV shaft for a 1992 Eclipse GSX.
I'm curious if they are the same...
I put that GVR4 tranny into my 92 talon that I bought from Tony, and when the CV shaft is installed there is about 1/8" play when it's in correctly. It almost seems as if the c clip was 1/8" closer to the Passanger wheel it would lock into place correctly. I just want to see if there is any difference in the axels, if not, that means the front diff is f-ed.
Thanks!
Kevin Swalchick.
Old 03-20-2006   #2
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Re: CV Shafts
Hey Kevin:My name is Nick,I work at brookdale mazda mitsubishi.It looks like there is two part #s for gsx mb526438 mb297992.I talked to tony he said to make sure you use the vr4 shaft. Just to let you know chris is now manager at luther suzuki. thanks Nick!
Nick G is offline   Reply With Quote
Old 03-20-2006   #3
Re: CV Shafts
Thanks Nick!
Old 03-20-2006   #4
Re: CV Shafts
I just checked Napa's online site, and the axel part numbers there are the same for right front CV shaft for awd galants (auto and manual) and awd talons/eclipses (auto and manual). I had always believed the CV shafts were identical.
I'll stop by tomorrow.
-Kevin Swalchick
Old 03-20-2006   #5
blageo23
AWD4G64
blageo23's Avatar
Re: CV Shafts
Same with Autozone and Checkers.
Old 03-21-2006   #6
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
Re: CV Shafts
I want to say abs is the problem but the catalog dont give me specs except green or Dgreen
Old 03-23-2006   #7
Re: CV Shafts
oh Ok. that might make sense... I'll stop in tomorrow!
Old 03-28-2006   #8
Re: CV Shafts
The diff is messed up. My shafts work fine in another GVR4 I just tried tonight. Thanks Nick for all the help tho. haha I just wasted a lot of money buying a broken tranny .
