Old 04-23-2006   #1
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
putting the head on and have some ?'s
Just wondering what people have to say for this. I will be putting the head on the shortblock tonight. I will be fastening it with arps. My procedure will be:
1. hand tighten studs into block(no thread lock, no oil, no grease)
2.spray copper on both sides of HG(stock) and drop on block
3.drop head on
4.coat upper thread with engine assembly lube(sticky and red)
5.washer and nut go on
6.torque pattern using chiltons.
7.30,60,100-105f/lbs
I have put heads back on blocks but not on a turbo car before. Theres a lot of pressure and heat on turbo car that just doesnt exist in camrys and the like.
I want comments and criticism, I want to use everyones knowledge.
Old 04-23-2006   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: putting the head on and have some ?'s
sounds good to me. Make sure there is no oil in the holes for the headstuds first though. Are you using arp's. I would use the molly lube if you have it, but I have doe it with the assembly lube before. I think the torue spec with ARP's is 95 though. Maybe someone else remembers.
7/25/09
Old 04-23-2006   #3
We have had the debate back and forth, but I use threadlock on the bottom side of the studs. I have had them back out of the head. Also, assembly lube isn't what you want to use, the real ARP moly lube is what you want to use. It should have come with your studs. The rest sounds good.
Old 04-23-2006   #4
If you don't use ARP moly lube, your torque specs are good with regular oil on threads. If you're using moly, go with 95 ft/lbs.
Old 04-24-2006   #5
Blue or red? I know that red is "permanent" and it would be a bitch if you ever had to take the studs out.
Old 04-24-2006   #6
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
red blue green purple etc. You can get many kinds of loctite
- Josh L.P.
Old 04-24-2006   #7
joesushi
Smells Like Fish
joesushi's Avatar
Drives: 96GSX
Have you ever had any back out since you started using threadlock?
Old 04-24-2006   #8
There are more differences between them than the color. My question was legitimate. Please stop posting.
Old 04-24-2006   #9
I use the blue stuff and have taken them out after putting loctite on. I have had studs back out on 3 different occasions before loctiting them, none since I have done that.
I blow out the holes with air, spray it out with carb cleaner, then again with air. Then toss blue loc-tite on the threads and lightly snug down the studs with an allen wrench. I torque to 105 ft-lbs with ARP lube. Get much higher than that and you can run into stretching trouble. I still replace them once in a while.
Old 04-24-2006   #10
Awesome. Blue is the standard on RC cars as well.
Old 04-24-2006   #11
Pimpin Dsmstyle
Br0k3N
My answer was legitimate too son. I was saying that there is more than 2 kinds of loctite. You made it seem as if you only thought there were two kinds. Want the exact strengths? I'll make it LEGIT ENOUGH FOR YOU.
Red - 262, high str
Green - 290, medium str, wicking grade
Purple - 222 low str
545 - thread sealant.
Don't have the specs on blue here at work. How much more legitimate do you want?
- Josh L.P.
Old 04-24-2006   #12
tim
tim's Avatar
Dont forget that there are different levels of strength between the same colors too.
It is just a general rule of thumb that red is more permanent, and blue isnt.
Old 04-24-2006   #13
iceminion
iceminion's Avatar
thanks to jet for keeping the post ON TOPIC, lol.
Old 04-25-2006   #14
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
I heard torquing them down to 105 would make the cylinders a little more egg shaped. That is what Mike used to say anyways. Maybe it doesn't matter that much though?
7/25/09
