07-13-2006
#1
Boost Junkie
Drives: I teleport
Lagging issues
I'm having some annoying lagging issues and also a mushy clutch pedal that lasts for the first 10 minutes that I drive. I have changed everything humanly possible that I can think of: Clutch master and slave cylinders, SS clutch line, transmission was rebuilt 8,000 miles ago and new clutch was put in 20,000 miles ago. The lagging is not consistent; some days it's there some days it's not. I can't figure out if the clutch is slipping or if there's a boost leak. Right before spool up there will be an obvious lag/bog and then the turbo starts spooling. The car is a 97 GSX with 108,XXX miles. Mods are: Shep stage 1 rebuilt trans, ACT 2600 clutch w/resurfaced flywheel, mbc, catback exhaust, bov, intake, hahn sidemount ic upgrade, and ic hardpipes. Any advice/input greatly appreciated.
07-13-2006
#2
Drives: A BMW
Re: Lagging issues
7 bolt? You may laugh at me, but check for crankwalk. I had tons of clutch issues, and my car was walked bad.
07-13-2006
#3
Boost Junkie
Drives: I teleport
Re: Lagging issues
Do you recommend a place/someone for checking for crankwalk? I know there's a vfaq but I'm afraid I'll jack something.
07-14-2006
#4
Re: Lagging issues
Just drop the oil pan an measure the thrust bearing clearance.
Was your clutch hydraulic system properly bled and adjusted?
As for your lag issue, check for exhaust leaks before the turbo.
07-13-2006
#5
Wanker
Drives: 95 M3
Re: Lagging issues
The problems could be seperate. What does your fuel system look like? Have you logged anything?
07-14-2006
#6
Re: Lagging issues
I agree, the problems sound separately related.
07-14-2006
#7
Re: Lagging issues
The english language kicks ass
Just measure the play on the crank pulley to see about crank walk. You will need a depth mic, dial indicator or a caliper to take the measurement. Pull the pulley out, take a measurement, then push it in and take a measurement. The difference is the amount of thrust bearing play that you have.
07-14-2006
#8
Re: Lagging issues
HAHA, I wrote that in a hurry. I guess it would have made more sense to say that the problems were unrelated instead of "separately related"... its too early.
JET's right. I guess I like doing things the hard way.
Do the rpm's drop when the cluth is depressed? Do you here a ticking when you depress the clutch and hold it to the flood? Have you ever had a problem with the clutch pedal sticking to the floor when you make a left hand turn (the pedal will stop a few inches short)?
07-14-2006
#9
Drives: A BMW
Re: Lagging issues
in addition to this, do you ever have clutch chatter? do you ever have inconsistant clutch engagement height? those are symtoms i had.
07-14-2006
#10
Boost Junkie
Drives: I teleport
Re: Lagging issues
I have lifter tick but that's there no matter what. Pedal never stuck to the floor on a left hand turn.
07-14-2006
#11
Re: Lagging issues
Sorry, double post.
07-14-2006
#12
Boost Junkie
Drives: I teleport
Re: Lagging issues
What is an "acceptable" amount of play, and what is not?
07-14-2006
#13
Drives: A BMW
Re: Lagging issues
^^^ do what Jet says.
07-14-2006
#14
Re: Lagging issues
Over .010" is out of spec. Over .025" and you had better call Houston, because you have a problem.
07-14-2006
#15
Boost Junkie
Drives: I teleport
Re: Lagging issues
lol, alright thanks, I'll take a look at it.
